C&D - Instrumented Test
Wait, aren't the "5-60", and the "0-60 with one foot of rollout" two different things? And isn't 5-60, simply 5-60 (i.e accelerating from a constant 5, then flooring it up to 60, without a so-called rollout)? Either wires are crossed here, or I'm totally confused, which is entirely possible.
I believe the big difference between 0 - 60 times and 5 - 60 times are mostly due to launch control rather than turbo lag. There was a big difference in those times for the NA 991.1 too.
The reason there isn't a big gap for the Corvette is probably because it doesn't have a good LC to use for the 0 - 60.
Yes they are different things. Your description is how I understand it. With 5 - 60 you can't use LC.
Regardless, the NA 991.1 had a similar gap between 0 - 60 (4.2 sec) and 5 - 60 (5.3 sec) according to Car and Driver's test. So at least for the 911, it doesn't seem to be turbo related.
Car and Driver posted their instrumented test of the 992. Good performance all around.
C/D TEST RESULTS
Zero to 60 mph: 3.0 sec
Zero to 100 mph: 7.2 sec
Zero to 130 mph: 12.4 sec
Rolling start, 5–60 mph: 4.2 sec
Top gear, 30–50 mph: 2.2 sec
Top gear, 50–70 mph: 2.6 sec
Standing ¼-mile: 11.3 sec @ 125 mph
Top speed (drag limited, mfr's claim): 191 mph
Braking, 70–0 mph: 140 ft
C/D TEST RESULTS
C/D TEST RESULTS:
Zero to 130 mph: 12.2 sec
Zero to 150 mph: 17.4 sec
Rolling start, 5-60 mph: 3.8 sec
Top gear, 30-50 mph: 2.4 sec
Top gear, 50-70 mph: 2.5 sec
Top speed (drag limited, mfr's claim): 193 mph
https://www.caranddriver.com/reviews...c-test-review/
Braking, 70-0 mph: 142 ft
G650 (07-16-2019)
