C&D - Instrumented Test
Car and Driver posted their instrumented test of the 992. Good performance all around.
C/D TEST RESULTS Zero to 60 mph: 3.0 sec Zero to 100 mph: 7.2 sec Zero to 130 mph: 12.4 sec Rolling start, 5–60 mph: 4.2 sec Top gear, 30–50 mph: 2.2 sec Top gear, 50–70 mph: 2.6 sec Standing ¼-mile: 11.3 sec @ 125 mph Top speed (drag limited, mfr's claim): 191 mph Braking, 70–0 mph: 140 ft |
How could a rolling start 5-60 mph take almost half again longer than from a dead stop?
Originally Posted by Sam Dickson
(Post 15968633)
Here is the actual C&D review. In it they mention why rolling start is 1.2 secs slower (4.2 vs 3.0) than launch control for 0-60mph. Also note it is a German spec 992 S being tested.
https://www.caranddriver.com/reviews...y-the-numbers/ |
Hmm, my 991.2 c2s 5-60 is 3.9 sec... C and D numbers.
Also, you need to keep in mind that the US is unique in how it records 0-60 times. The time is not from a complete dead stop.
Rather, it allows for a 1 foot rollout which the ROW does not. This adds at least 0.3-0.5 of a second to the 0-60 time. If the time was genuinely recorded from a dead stop then it would be more like 3.3-3.5 secs. |
Originally Posted by Chris3963
(Post 15969393)
I'm amused at how they refer to the 991.2 GTS as "the old GTS". lol
Originally Posted by stealthpilot
(Post 15969451)
I checked this out and you are right. I thought it was just motortrend that did that, but it seems all US publications do that. Seems like cheating. with foot you are probably testing 5-60
Europeans don't care about this because they don't have any drag strip heritage. 5-60 rolling start was developed to simulate a more real-world launch because few owners are willing to perform the 6000-rpm clutch drops that used to be required to extract maximum acceleration from older Porsches on the street. Developing a more moderate clutch drop that could be replicated consistently proved impossible, so the solution was to put the car in first gear, drive at a steady 5 mph, and then go full throttle and shift for maximum performance until 60. |
Originally Posted by iliveoncaffiene
(Post 15968643)
Rolling start you're not in boost and not revved up like you would be with a launch control start.
Confused. How would the foot of rollout better replicate 0-60 if, presumably, you can’t use the launch control while rolling? Or, can you use LC by letting off the brake only slightly for that first foot? Need help understanding.
So much expertise, so much confusion.
Originally Posted by chance6
(Post 15971093)
Indeed, rolling start is meant to simulate 'real world' acceleration, which sometimes can expose a turbo heavy engine...
Meanwhile, a C7 Corvette with the automatic did 0-60 in 3.7, while the 5-60 rolling start was only slightly slower at 3.9 seconds. This, of course, is the worst case comparison, turbo/manual versus big NA V-8/auto. But it shows than any idiot can get the Corvette under 4.0 seconds by simply mashing the throttle to the floor. Achieving a similar time with the GT manual requires a degree of clutch slip and speedy shifting that might be beyond the abilities of willingness of many drivers. |
Originally Posted by Valvefloat991
(Post 15971571)
Precisely. According to Car and Driver tests, the 991.2 GTS 0-60 (with the rollout) measured 3.4 seconds, while the 5-60 rolling start was 4.6 seconds.
Wait, aren't the "5-60", and the "0-60 with one foot of rollout" two different things? And isn't 5-60, simply 5-60 (i.e accelerating from a constant 5, then flooring it up to 60, without a so-called rollout)? Either wires are crossed here, or I'm totally confused, which is entirely possible.
