Hello everyone
just picked up my first porsche from the dealer.
its a 992 carrera s.
i have two problems and maybe someone could help me.
1. Except the 2 keys, it came with 2 remotes, and i have no idea what is the remotes use (first photo attached).
2. Its a new car. I live in Romania (eastern europe) but i picked up the car from Germany. Reading forums, i understand that i have to drive the car long ways and not over 4000rpm for 3000 km for the breakin period, so wanted to drive the car from Germany to Romania.
after 400 km, i received a chassis fault error (photo 2 attached).
the car drives normal but i can not change from normal to sport/sport plus/wet.
if i stop the engine, the error disappears for a while.
delaer programmed me in two weeks
thanks in advance for your answers!
good evening Photo 1 - remotes Photo 2 - chassis error
I’m guessing the two black blocks are the new Porsche tracking transponders. Do you have the Porsche Vehicle Tracking System optioned? I’ve read elsewhere that the new transponders are thinner and fatter than the 991 ‘credit card with a bulge’ ones.
as for ‘run in’. I asked this question to Evo X, the dealer attending the Porsche training who offered to ask any questions posted (excellent thread followed). Porsche engineers said that the 911 was a race car for the road and required no kid glove handling. All the engine running in is done at the factory.
There is also a school of thought in the motorcycle racing community that piston rings shape to the cylinder properly when they are under pressure so driving gently actually prevents that happening and robs the engine of its potential maximum power. I will leave you to google.
I have PVTS but do not have those black little boxes. Do not understand why you need them for PVTS either.
about running in, dealer told me to make sure engine is warm (as always) but engines are being run in at factory. My manual says nothing about running the engine in.
It works a bit like dual factor authentication in the world of computer security. You need both your key and one of these transponders in the car, otherwise Porsche deems the car to be stolen. With normal tracker systems you have to call the tracking agency and tell them your car has been stolen.
If you have PVTS on your car, it seems highly likely that the transponders are in your car somewhere.
My mate spec’d PVTS and never realised (until he came to sell the car) that the two transponders were in the manual wallet in his glove box. He had a 991. The transponders look like small black credit cards with a battery sized bulge in them.
Here’s a picture. Novel way of attaching the transponder. You can get little pouches with a keyring attachment but linking key to transponder seems to defeat the ‘dual factor authentication’ feature.
The photo with the break in period information is a screenshot from “GOOD TO KNOW” application, which is released by Porsche.
mentioning that the model chosen in the app is regarding the 992, the model in the subject.
BMW M cars also have a break in period with an oil change at 2000 km..
maybe i am wrong but i will also do the oil change.
mentioning that the model chosen in the app is regarding the 992.
Yes. I’m with you. Recommendations like this come with most cars.
It’s certainly a contentious/controversial idea that piston rings shape better under pressure. And there’s a tonne of debate on-line - with very strong assertions on both sides. That’s why I asked the question.
What is interesting is that the racing boys do actually open up their engines and show pistons that have been run in hard vs run in gently after completing a whole race season. You can see the difference; that much is true.
Believers compare dyno readings. They also refer to manufacturers running engines to max revs through the gears and back at the end of production. Then we have the Porsche engineers themselves apparently deviating from the handbook. There’s definitely conflicting views.
We each have to make the choice with our own cars I guess. I certainly have confidence that Porsche manufacture their engines to very fine tolerances and to work hard.
It would be interesting to hear more from those who race 911s.
