Auto Emergency Braking and Radar Detectors
Since the 992 has Forward Collision Warning and Automatic Emergency Braking as standard, I'm wondering if that will render a radar detector useless. If the systems are radar based (I think they must be), I'd think that they would send out a constant signal that would trip a radar detector. But perhaps, they use a different frequency. Does anyone know? Blind Spot Monitoring, Turn Assist Rear Monitoring, and Animal/Pedestrian Detection systems are optional. Will any of those interfere with radar detectors?
Cant u just memory mute out that frequency?
What if it’s a frequency that the police also use?
I have forward collision warning and automatic emergency braking on both my Turbo S and on my E63S and the radar detection systems on both cars work perfectly.
G650 (08-01-2019)
The bigger issue is not what it does to your detector but rather what it does to others around you. I had an older V1 that threw so many false warnings due to all this radar nonsense that I just gave up with using one.
Thanks stealthpilot. Limegreen, I recently upgraded to a Escort Max 360. It's pretty quite. It doesn't seem to pick up the various systems on other cars. My prior unit was a 9500ix, and that became useless. It tripped at every other car on the road.
I don't have any idea what is used in Europe. I don't know if the cars use the same frequencies as they use over here or what the cops use.
I hope this system is better than Benz’s. Apparently on the track the car applies the brakes as you approach other cars on track that you are trying to pass...
I dont think it matters. I believe the standard equipment is camera based, not radar.
JHesketh (07-19-2019)
