The Porsche 992 Aftermarket Wheel Thread
#46
Does the FF10 come in 992 sizing? If not, any idea when?
#48
sucks, hopefully they become an option soon. I have FF01 in IPA on my 718 Cayman and want to put the FF10 on my incoming 992.
#50
The aftermarket generally has great looking wheels for most cars but as OEM wheels go Porsche has the very best in my opinion. There is not a single wheel available on the 992 that I don't like.
#51
What about Vossen wheels? Their HF5 look like GT3 rims. I also like their HF3 rims. I haven’t inquired with them but they indicate they can build to fit most bolt patterns and offsets and they have sizes up to 23”. Would be nice to see a 21/22” set up with HF5s.
#52
I reached out to HRE and it seems like the recommended offsets are below if you plan on using the OEM tire setup.
Fronts 20 x 9 et45
Rears 21 x 11.5 et58
I feel like there is more room since I am currently running 15mm spacers front / rear.
Anyone else care to share their offsets?
My initial specs were:
20 x 9 et 40
21 x 12 et 59
Fronts 20 x 9 et45
20 x 9 et 40
21 x 12 et 59
AlterZgo (07-20-2021)
#53
Fronts 20 x 9 et45
20 x 9 et 40
21 x 12 et 59
Fronts 20 x 9 et45
20 x 9 et 40
21 x 12 et 59
I have 14Mm spacers I tried on my spyder wheels. 14MM had my rear wheels 6-8MM past the fender just parked. The fronts where fine. But how on earth do you have 15MM on your rear and it look flush? Are you lowered?
#54
There's a slight poke in the rear but it's fine for now.
Below is running 15mm F/R
![](https://live.staticflickr.com/65535/51323134153_63fec4114c_h.jpg)
![](https://live.staticflickr.com/65535/51323927585_bd59246b38_h.jpg)
![](https://live.staticflickr.com/65535/51322193447_bd51b36c54_h.jpg)
T1M3LESS911 (07-20-2021)
#56
Can you confirm the standard offsets on these Flow Forms for the 992?
#57
This is very interesting.
T1M3LESS911 (07-23-2021)
#59
I believe the spyders have a different offset than the classics, which may explain the difference you saw?
