992 Turbo and Turbo S 2019-Current
Sponsored by: Porsche San Francisco
992.2 turbo RWD & manual with "touring package"?
Old 09-19-2024, 07:47 PM
  #196
elvisdoc
elvisdoc's Avatar
Originally Posted by CM991
It's standard for C&D tests.
Nope. Sounds like they launched it. "To get those times requires engaging launch control. It’s as easy as turning the drive mode **** on the steering wheel to Sport or Sport Plus. Stop the car. Hold the brake with your left foot and hold down the accelerator with the right until the engine revs to 5000 rpm. Look as far down the road as you can before releasing the brake, and whooaa. Keep it floored for 21.4 seconds and you’ll be going 180 mph."
Old 09-19-2024, 07:50 PM
  #197
CM991
CM991's Avatar
Yes. They use LC but start the clock after the vehicle cross a foot.
Old 09-19-2024, 07:51 PM
  #198
elvisdoc
elvisdoc's Avatar
Link to C&D protocol for this car?
Old 09-19-2024, 07:52 PM
  #199
CM991
CM991's Avatar
Car and Driver - We're Making a Slight Change to Our Acceleration-Testing Procedure
Old 09-19-2024, 07:57 PM
  #200
elvisdoc
elvisdoc's Avatar
"In general, acceleration times for most cars will improve by about 0.1 second with the new procedure."
Ok we can call it 2.3 s. ​​​​​​​
  #201
CM991
CM991's Avatar
​​​​​​​More like 2.4-2.5
Old 09-19-2024, 08:02 PM
  #202
elvisdoc
elvisdoc's Avatar
More like 2.4-2.5
Ok maybe but with a tune of the 992.1, we be better. BTW,with the new hybrid setup, what are you predicting? With the results on the 992.2 GTS, can you really say it will be worse than 2.2 or better?
Old 09-19-2024, 08:19 PM
  #203
CM991
CM991's Avatar
The only thing that can make the TTS faster while keeping Lambda 1 is a larger engine, bigger turbos and hybrid. I’d expect a 3.9-4.0L, 710-730HP and 0-60 in low 2s.
Old 09-19-2024, 10:05 PM
  #204
rmrmd1956
rmrmd1956's Avatar
More like 2.4-2.5
At the bottom of that C&D test page it literally says “Standing-start accel times omit 1-ft rollout of 0.2 sec.”
I
Old 09-19-2024, 10:13 PM
  #205
elvisdoc
elvisdoc's Avatar
I
Article literally says .1 second difference. Other quotes .2 sec. You sound like .1-.2 sec matters to you? Relax sparky. That puts it basically tied with the Ferrari 296. And it's bulletproof.
Old 09-19-2024, 10:27 PM
  #206
Scorpio830
Scorpio830's Avatar
Default Very exciting but not revolutionary
I guess we all want the newest toys , I def do . But none of this is ground breaking new ability . I just sold my tuned 992 tts . Had 800 hp and was lighter then stock by 30-40 pounds due to me changing some pipes . Fast to the point where it was dangerous . And not engaging. Sold it and just got a brand new 24 gts awd manual . I’ll tune it and get another 100 hp which will take it to close to 600. That power is better distributed via an awd with rear axle steering . I test drove both 24 992 gts in rwd and awd with manual . Long story short , it’s the equivalent to what a turbo 992.2 turbo with manual would be . Ultimately/ we already have all this now . And truthfully, I like my tachometer . Not sure I would fall for the usual Porsche marketing and make the switch . We have it good now . I would like to read and see something that’s a bit more exciting . Though manthey is more aero then power related changes , they are actually cool and relatively diff over the years . This 992.1 vs 992.2 is a snooze fest in my humble opinion .
Old 09-19-2024, 10:33 PM
  #207
elvisdoc
elvisdoc's Avatar
Originally Posted by Scorpio830
I guess we all want the newest toys , I def do . But none of this is ground breaking new ability . I just sold my tuned 992 tts . Had 800 hp and was lighter then stock by 30-40 pounds due to me changing some pipes . Fast to the point where it was dangerous . And not engaging. Sold it and just got a brand new 24 gts awd manual . I’ll tune it and get another 100 hp which will take it to close to 600. That power is better distributed via an awd with rear axle steering . .
Agree we have it all now but a TTS is also AWD with rear wheel steering so not sure your point on that?
Old 09-19-2024, 10:35 PM
  #208
CanAutM3
CanAutM3's Avatar
Received 1,362 Likes on 634 Posts
Don't see anywhere in article that it says it's a rollout. My statement stands. Add hybrid power and it will likely be in Plaid territory. Of course EV's will always beat that. But I don't want to drive a toaster.
It is actually printed in the test results: the 1-foot roll out took 0.2 seconds, which is excluded from all the acceleration times including the quoted 0-60mph. See last sentence in screenshot below:
Old 09-19-2024, 10:38 PM
  #209
Scorpio830
Scorpio830's Avatar
Hence I got a 992.1 gts in awd but manual . 2500$ tune will put on par with whatever the new so called manual turbo will be . I got really comfortable with the tts in awd and ras. Would not want 600hp in manual without it .
Old 09-19-2024, 10:41 PM
  #210
elvisdoc
elvisdoc's Avatar
Yea I saw the fine print but thanks. Like I said, that changes the C&D time to 2.4 seconds 0-60. Not bad and still right there with the Ferrari with only ICE. Not gonna quibble over .2 seconds.
Quick Reply: 992.2 turbo RWD & manual with "touring package"?
