Lithium Battery charging
Do you guys have any opinion/knowledge of how often and under what circumstances we should be charging our batteries? I have a dash cam that monitors my car when parked. I do drive my car year-round but during crappy weather in the winter, I may go 2 to 3 weeks with out driving. should we be topping off our cars regularly?
i have trickle chargers connected to all my vehicles including motorcyles and don't have battery issues.
HOTCHKIS (01-07-2024)
Basic Sponsor
this is the proper trickle charger for the Porsche 992 Turbo. With todays batteries it is very easy to use the wrong type of charger on this car.
TRICKLE CHARGER FOR PORSCHE 992 TURBO S
WORLD MOTORSPORTS
2170 W 190th Street Torrance, CA 90504
(310) 533-8900
- Akrapovic - BMC - TechArt - H&R - By Design - AMS - CSF - Kline - NGK - TiLugs - HRE - M Engineering - ID Injectors -
FULL SERVICE INSTALLATION FACILITY - STATE OF THE ART WIND TUNNEL DYNO - ECU TUNING
WORLD-MOTORSPORTS.COM
(310) 533-8900
I bought the Porsche lithium ion charger and did a direct connection to battery as I could never get the cigarette lighter to stay on despite trying all the tricks from forum. It never worked. My dealer told me to put in regular (non lithium) mode and try that. Not sure if that works as haven’t tried it yet. The new lithium ion battery while a lot smaller doesn’t keep a charge for long.
Longer than a week, plug it in, battery is highly expensive and if it dies, not fun.
I’ve had the same CTEK charger you posted for a year and half. Used to charge from footwell and was inconsistent not matter what I did but sometimes it stayed charging after driving the car for extended period and connecting the charger immediately to footwell outlet in car and locking the car.
Last week, I connected the charger directly to the battery with the supplied connector and now no matter what I do, it charges for a day and stops. It is properly connected to pos and neg terminals, charges to step 7 and 8 for flat/pulse on the charger but it never goes over 24hrs. Infuriating and the only thing I dislike with 992. I want to buy another charger but something as simple as trickle charging should not be this painful 😀
991 trickle charging was consistent and drama free.
Thoughts?
My friend recommended a NOCO. It has a setting for lithium. I have it but have not used it yet. He has one in his shop and he says it works great. My porsche one broke as I said above. I figured I would give this one a try
He ran a cable directly to the battery. I guess I will have to leave the hood slightly ajar when in use.
I use this one on my car without issue hooked up directly to the batter (except negative terminal to the proper ground location)....with the Lithium option selected. Also has the AGM function to charge the other vehicles when needed as well. I've used this brand (Batter Tender) to charge Porsche vehicles for about 18 years without any issues or problems and this one was under $100.
Ditto. Use this one (Battery Tender) too. I have 2 of them. Use LifePO4 on the TTS and AGM/Flooded for my other P cars. Hooked directly to battery terminals/ground with the charge wires routed up near passenger wiper blade. When I park/store the frunk P cars I actually leave the frunk open (just slightly latched but not fully pressed down/closed) with the tender charger connected. No problems so far.
cheers,
L76
cheers,
L76
A little more expensive but a great garage accessory as it automatically detects polarity and battery type (AGM or lithium) so technical buffoons like me cannot go wrong!
https://www.ctek.com/uk/battery-char...-24v/cs-one-uk
I bought my charger from the dealer. Before a 3 week trip to Australia I plugged my 2022 TTS to the cigarette lighter, and quickly noticed a strong burning odor coming from the garage, so I quickly unplugged it. Didn’t have time to figure out what the hell happened. Appreciate feedback on how you trickle charge this car.
I have a NoCo hooked up directly to the battery terminals. The Porsche charger didn't seem to work that well. It would barely come up to the maintenance charge level on it.
