Dead battery woes
Hi, to any who have experianced this or want to avoid this type of thing in the future we make a product that can get you out of this emergency with ease and relative simplicity.
It is called the Antigravity Batteries "Clampless Harness Kit". Its a simple harness that connects to your battery then you can connect an Antigravity MiCRO-START Jump Starter to it and open the frunk OR start the Car easily.
The problem with trying to energize through the fuse box busbar is that it doesn't transmit enough current at times to energize the hood release on the car because the battery is dead and is taking the energy of the battery you connect to the busbar. It has I think a 18 awg wire there so not very good. So you need to go directly to the battery with a GOOD Jump Starter, that has a decent capacity and current connected to a thicker wire gauge to make sure the Cars system is energized, then it will easily pop the hood.
Our product can be found here to see the details >>>> https://antigravitybatteries.com/pro...s-msa10b-long/
A video to explain it below.
https://www.youtube.com/watch?v=-pMXB1SV_kQ
The following 2 users liked this post by eclou:
daveo4porsche (07-02-2023),
Patton250 (06-26-2023)
Premium Sponsor
You've introduced me to another rabbit hole of RC battery connections. SAE, EC3, EC5, EC6, EC8, IC5, 3...... I am going to run a standard ring terminal to SAE plus on the car, then get am SAE to EC5 adapter to plug into my GooLoo booster. Your EC5 to ring terminal would work but then I could not use my existing trickle chargers. This way I can trickle charge the car then use the adapter to power from my booster if necessary with the exact same harness
Best regards,
Wow brother I’m really sorry that happened to you. What a pain in the butt. Do you think if you had had a tender cable accessible for a jump starter it would’ve turned over?
Only thing I'd just want to touch on and advise exercising caution on is if you were at any point looking to actually jump/boost the car..typically the standard SAE charging cables(pigtails) are a smaller gage and not rated to handle the amperage a jumpstarter/booster outputs so they could be damaged in that regard. Also, without any inline protect(diode assembly) there may not be anything to prevent the backflow of charge from vehicle once it is started from going back into the jumpstarter/booster which could also damage it. Again, just a couple things to note..
Best regards,
Best regards,
Best regards,
Best regards,
Antigravity (06-26-2023)
wiring adapters came in from Amazon:
1)Ring terminals to SAE adapter with inline fuse 10 gauge
2)EC5 to SAE adapter 10 gauge
The boosters I have are two GooLoo GT3000 and GT4000 which are 3000A and 4000A jump starters. They have a proprietary shape plug for the battery clamp cable that I thought looked closest to the EC5 connector type. Its not a direct fit. I decided to try to make it fit so I trimmed back the blue insulators and this allows the EC5 adapter to fully seat into the jump starter. Hooked up to the car battery and appears to have a good connection. It would have been far easier to use the Antigravity harness or a Noco harness but I don't have either and didn't want to have to reinvest in yet another system
EC5 adapter on left after trimming, EC5 adapter in middle untrimmed, proprietary GooLoo plug on right
modified adapter seated into jump starter
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,172 Likes
Sorry to hear about this miserable experience. How did they get the car on the flatbed with the tow hook, given that it won’t go into neutral if the engine won’t start?
Not sure how the second tow driver did it. After 8 hours of waiting, I had my wife pick me up and he picked it up the car after I had left.
I think go jacks are best way to roll the car, provided that the car is on pavement.
they used a combination of go jacks on all 4 wheels and skids to ease the jacks over the flatbed transition. The pull of the tow hook is off center so one of the crew pushed into the drivers front wheel while I pushed into the passenger back wheel to try to keep it straight as the winch pulled. It was a symphony of moving parts
on mine, he (1 guy) simply pulled it on to the flatbed with wooden planks & micro adjustments to the angle of the flatbed itself - got it off the same way - he was definitely experienced at it...as he told me how many lambo's and mclarens he's done.
didn't use the tow hook...he wanted to use the undercarriage and it work so smoothly he looked like a true professional - i think the fact that i am in the NY metro area gets him plenty of experience
It seems like this battery issue is a common problem. Is there a reason several cars have the problem or is it just common battery issues? I've not had any concerns with my previous 911's and I live in Arizona which is notorious for baking batteries. Could some of these been caused by mods?
- keyless entry/start (something has to "listen" for the RF signal) that takes power
- online status for the Porsche app - this is a wireless communication and the car has to be "awake" - more power demand
- in car security system (the flashing red light)
- interior monitoring
- other's I don't know about
Now what I do believe is reasonable but porsche does not provide:
- higher capacity factory battery - they know these systems are "alive" and need constant power - they should provide a battery that can handle the car being idle for at least 6 months (assuming the car is behaving correctly and as designed which in my case due to a bad module it was not)
- a more supported and direct/easy method to externally maintain the 12V battery vs. alligator clamps
- if they need constant power for long term storage they should provide a well integrated, easy method for doing so.
- porsche should make their vehicle's easier to "recover" vs the "jump start the fuse panel to get the frunk open" procedures we all have endure currently…
Spoiler
good 12V trickle charger + 12V booster is requirement equipment these days - unless the car is driven frequently enough and long enough duration.
I don’t let a newer car with lithium battery sit longer than 2 weeks without being on the trickle charger. The old days are over, these new cars have constant loads like above said, they are always listening and uploading. Be safe and if over 2 weeks, charge it. They are designed to drive not be stored.
