Hey Eclou, I logged onto My Porsche with the hopes it would be listed somewhere on my profile for my TTS with Sport Pkg. but no luck, it wasn’t listed, it just says Turbo S Wheels
The wheel color is advertised as Platinum semi-gloss. Unfortunately I can't find a color code for it anywhere, but I found this thread where some folks have been trying to reverse engineer what **seems** to the the same color...
My dealer told me it’s 1NM. I am getting my wheels painted this week.
1NM is the option code for the dark silver wheel finish on a 992GT3. Its not a color code. I read through the entire thread that wotaskd provided about and the 0B5 color code which was called Platinum Silver on various other Porsche wheels is likely the closest if not identical paint code. Someone even provided the actual Glasurit formula attached so this can be used to refinish or get touch up paint made.
Here is also a link for a touch up paint kit of 0S8 listed by a european company COLORNDRIVE
Thanks eclou! I’m doing the exact same thing. I even went so far as to consider getting the winter wheel package to get that color wheel but they are narrower wheels.
The paint color says Dark Silver Met… I hope the Met doesn’t mean Metallic since it clearly is not a metallic color.
When are you getting them painted? I’m still 2 weeks from delivery and would love to see your wheels when you’re done. They are definitely my favorite Porsche wheel.
I'm looking all over to see what paint is available in OS8 - so far the only one I can find is Spies Hecker, which is fairly expensive. I'm trying to find an equivalent in Chromabase, or some other more reasonably-priced paint. Here is the formula for the Spies Hecker - $750 / gal plus $150 / gal for reducer . . I plan on using a satin clear aircraft polyurethane - indestructible.
