What'd be the Turbo S Nurburgring lap time?
My guess is that answer is on the slipstream of the Turbo when you create a build code such as this generic one...I see 7:00, 7:01 or 7:18.
http://www.porsche-code.com/PMNY3CD2
AlexCeres (08-23-2020)
This is interesting....certainly no trouble staying on the tail of a GT3 RS
https://youtu.be/rzd5NSw0wRk
GT3RS has a 6:56 time, which is simply incredible for that platform and yes a reflection of heroic driving
I bet the TTS will be closer to 7:00 than people think...
The following 2 users liked this post by Pad Bender:
AlexCeres (08-23-2020),
TopspeedPT (08-29-2020)
You should be aware of what is happening here between the 3RS and the Turbo.
This is the Porsche Masters training event at the Ring. The student is in the Turbo and the instructor is leading in the 3RS. It's a lead follow format where the instructor only drives as fast as thinks the student is capable. All the while the instructor is looking in the rear vision mirror and providing constant commentary (you can hear it in the background) on where to brake, turn in, etc while keeping an eye on the student behind....mostly with only one hand on the wheel. If the instructor in the 3Rs wanted to disappear...he could...in heartbeat.
The GT3RS is insane on the ring for the power it has.
It really should be 7.00 flat......the Nissan GTR Nismo ran 7:08.......... 6 years ago with 600 hp and a 6 speed DCT........ More power, more gears and 6 years more development and much higher MSRP ????????? HOW COULD IT NOT..............
Ring times are very dependent on tires. I don’t expect a 7:08 time with the standard PZeros, since those are street tires. Slap on some of the Cup 2 Rs from the GT2/3 RS cars then the times will be a lot faster.
Probably under 7 min.
The following 3 users liked this post by TopspeedPT:
The Nissan GTR ran 7:08 with run flats........... one of the worlds worst tires for performance..........YES RUN FLATS that weight 42 pounds each......... Sub 7:00 easy.........
