Center Cap Remoal
Maybe there's a different forulation for P o rings as drain plug removal probs seem to be blamed on the o ring
when I first tried to take mine off I used a little tool that came with the car. Had to really pry hard and I it actually started to separate the cap from the backing. That’s when I decided to just drill a 1/8 hole and use a pick to remove. I put a small pice of clear tape over the hole to keep moisture out although never had any get in before the tape. The cap can only go on one way as it is keyed with a notch in the hub. Take a sharply and put a mark on it to index and some silicon grease on the o ring. (See pictures at the top of the post) carl
Next time you have the cap off, place the tool against it and take a look.
Does that tool come with the car?
If you don’t get the tool in all the way which isn’t that easy at first it can separate the cap and scratch the hub.
It’s personal preference but I like my way very simple and fool proof.
Don’t do it if you can’t live with an 8th inch hole in the Which you can’t see unless you’re on your knees.
Doesn’t bother me ,when I sell my car if it bothers the buyer I’ll buy 4 new caps..
The cost of convenience and simplicity!
Push the tool all the way in, then make sure it's biased against the edge of the cap before you start rotating it down as a lever-arm. This ensures the little scooped end goes behind the cap rather than against the edge of the cap.
The following 2 users liked this post by Mech33:
GrantG (10-03-2022),
marklondon (10-04-2022)
With the tool properly engaged, it presses against the back of the hard plastic backing and won't put any force on the cosmetic front cap. Unfortunately it does take a bit of finesse sometimes to make sure you're engaging it just right.
