PSA: emissions testing fail!
I have a Cobb access port, and love the tune for my 991.1. In Connecticut the car needs the mission testing every two years. Essentially they plug something into the OBD 2 port and determine if all the emissions components are functional. $20 for the trouble.
I contacted COBB in advance and they advised uninstalling before testing. I did so, and drove to properly to the testing station the next day, probably 2 miles or less.
Anyway, the car failed because none of the mission controls had enough time to reset themselves after the ECU was re-flashed. The guy at the testing station asked me if I had replaced the battery. Of course!
I drove it for a few days, probably 100 miles, and had it re-tested today, and passed no problem.
Hopefully someone else can avoid this hassle in the future.
Glad you got this solved. O2 readiness is a PITA.
To complete the PSA, O2 sensors require 30-50 miles of varied driving before they will show as "Ready". This goes for any hard reset to your ECU (i.e., reflash, battery swap, etc.).
Roberttran: no there was nothing actually wrong with the car and everything was functioning normally. It's just a quirk of the electronics that it takes some driving after resetting the ECU to get everything to register properly for the emissions inspection.
Start engine, idle cold for approx. 2 min, 10 secs.
Accelerate to 20-30 MPH, Maintain steady speed for approx 3 min, 15 secs.
Accelerate to 40-60 MPH, Maintain steady speed for approx 15 mins.
Decelerate and come to a stop. Idle in gear* for approx 5 mins.
^^^^ must be done twice
A quick search will show a ton of threads about resetting the sensors. The procedure is detailed and not to exceed 3,000 RPM:
