Harsh ride
I am shopping for a late model used 911. Test drove a 2014 S model yesterday and noticed that the ride is rough. The car did not have a list of the options on it so I could not pinpoint the reason for the harsh ride. Can anyone help with what would make the car ride harsh?
The recommended tire pressure is based on a full load and crazy fast speeds and that is what most dealers will set the tires at. This can result in a pretty harsh ride. There is a partial load/comfort pressure setting that lowers the recommended pressure considerably. I would look there first as to the culprit.
afk (05-29-2020)
Received 5,407 Likes
Harsh compared to what?
The Ox (05-29-2020)
I've owned both the 991.1 S with PASM and Sport PASM (both had PDCC, though) and found them very comfortable on long trips - not harsh at all.
Dealers - even Porsche dealers - seem to set the tires at the max inflation listed in the door jam (36 front/44 rear) which is suitable for autobahn speeds (160 mph +) (!) and give a rather harsh ride.
The comfort settings in the owners manual are set considerably lower (31/34 for partial load comfort, if my memory serves) and provide a far more comfortable ride.
Like others have mentioned...it was probably due to the tire pressures.
I've found that S models seem to have a more firm suspension that non-S models. My 1999 996 for example is supple, even over massive potholes, heaves, dips and bumps. So much so that I first worried that the shocks were shot. But the car was setup a plush ride as a base 911 compared to my 2000 Boxster S.
Try driving a non-S and see what you think.
My comment on the harsh ride is based on one of my previous cars which was a Maserati Grand Turisimo. That car has a Ferrari V-8 engine and only one tire setting of about 33psig. I did not think that that pressure detracted from the handling as the car has large low profile soft rubber tires.
PS I did not drive it an the autobahn.
Potential reasons:
A few months ago I tested a 991.1 and a 991.2 back to back, both with PASM, both in normal mode. The 991.1 had a noticeably harsher ride.
- No PASM at all is harsher than PASM in normal mode. (Don't know whether the 991.1S ever came without PASM)
- Large wheels are harsher than smaller wheels (20" vs. 19")
- PASM in sport mode is harder than PASM in normal mode.
- Sport PASM is lower and harder than PASM (SPASM = -20mm, PASM = -10mm)
- Tire inflation.
The greatest ride differentiator in my experience is whether a car has PDCC or not , assuming identical tire type/pressure settings and oem susp options and its console settings . When in straight ahead freeway cruising type driving , these computerized e-strut drop-links for the front and rear sway bars act as if the left and right sides of the car are decoupled ( i.e., as if no bars ) so a very calm quiet luxury car sensation is experienced but maintaining the usual steering wheel road feel ....then the e-struts immediately adjust roll stiffness depending on real time handling demands from driver/chassis/ susp button as you turn ....resulting in almost a " banked into the turn " sensation at high g forces ...I love this and have had it in past two 991s and personally would not buy a 991 w/o it !
Vast majority of 991s do not have it , even buyer-spec'd ones , but something for potential owners reading this to consider if you drive long straight highway distances ( of many hundred of miles) from point A to point B like I do from SF Bay Area to Tahoe via I-80 or SF Bay Area to SoCal via I-5 over many stretches with poorly maintained pavement .
TurboS_GG (05-31-2020)
I agree with most posts that the most likely reason was tire pressures way too high, but want to add that tire age/model can also be a big factor. If the tires were original PZeros, those have a reputation for getting harder from heat-cycling faster than others. My switch to the new Michelin 4S's produced a notable improvement over my prior PZeros despite the PZeros being only 18-20 months old. All of the other advice concerning suspension variations, PDCC, and PASM were great too.
But it could also just be a matter of personal experience. I consider my SPASM/PDCC car to have a firm ride, but not a harsh one. My 2001 M3 was the epitome of harsh!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Tire pressure for me as well. My cold pressure settings are now 30/33, warming up to 33/36. I was originally using the Full Load tire pressure settings, where at full temp would reach pressures around 38/41. While getting serviced at dealer, the loaner Boxster had a much softer feel to it. When I got my GTS back, I lowered the tire pressures to get a much more comfortable ride.
