Don't laugh
Don't laugh
Don't laugh but I find getting in and out of a 911 a bit of a contortionist act. This is really the only negative in my short time in the 911. I'm sure I'll get use to it. My 3 most Recently rides include R56 Mini, E90 M3 and T3 Touareg.
There is a proper technique. Then again, it all depends on how tall and how much someone weighs.. It can make things easier or harder.
https://www.youtube.com/watch?v=CjNQnrRv2Jw&sns=em
Someone once made a thread about it. After that, there was one on how to close the door
Someone maybe can dig them up.
Bingo. The high sill makes the frame more tub like and probably more rigid but also makes me kick up to get in.
Mix in a bit of yoga into your daily routine.
If you have memory seats in your car, you should check to see if you have Comfort Entry. If you do be sure it is enabled under the settings accessible from the stalk controls (or thumbwheel in the newer cars with multifunction wheels). That will move the seat back and raise/retract the steering wheel to make it easier to get in and out. Remember that this setting may be enabled/disabled per key.
