Took my '17 991.2 C2S 7MT to the 1/4 mile drag strip...
Old 05-22-2017, 08:07 PM
sticky
sticky's Avatar
Originally Posted by mac10
Not to be a story topper. 991.2 C4S PDK(w/ high-flow cats & tune). I am just now realizing that I ran that time with 21" aftermarket wheels, wondering if the stock 20's would give a different result..?
You were on 21's when you did that? Wow.
Some light 20's with better rubber would definitely help.
Old 05-22-2017, 08:09 PM
sticky
sticky's Avatar
Originally Posted by wisky
Glad to see more timeslips for these cars!
11.1 is killer fast - the 1.6 60 FT might not be possible on the RWD models without slicks...
I plan to run a Hoosier 18 inch drag radial.
Anyone know if 18's clear the rear brakes? I would think so but would be good to know for sure.
Old 05-22-2017, 08:35 PM
wisky
wisky's Avatar
I would think 18's clear the rear brakes no problem. What size tire would you run? Would you run an undersized tire to shorten the final drive ratio?
Old 05-22-2017, 08:44 PM
VWfamily
VWfamily's Avatar
How fast was the Ford F-150 in the pic?
Old 05-22-2017, 08:50 PM
wisky
wisky's Avatar
The black truck was a F250 6.0 Powerstroke turbo diesel, I didn't see what it ran.
Old 05-22-2017, 09:17 PM
sticky
sticky's Avatar
The Hoosier 315/30/18 probably makes the most sense.
The difference in final drive should be minimal.
Actually, did the math. The difference from the factory 20 inch wheels which are 305/30/20 I believe would be -6.9%. That's fairly large.
Old 05-23-2017, 12:47 AM
Valvefloat991
Valvefloat991's Avatar
Clearing the brakes isn't the problem. It's clearing the rear suspension pickup points. 18s won't work.
Old 05-23-2017, 12:52 AM
sticky
sticky's Avatar
Well, this is depressing. So 19 inch is the smallest drag tire option? Man...
Quick Reply: Took my '17 991.2 C2S 7MT to the 1/4 mile drag strip...
