Best Tire For Reduced Noise
#46
Also, you may want to review www.auto-decibel-db.com for published interior sound level tests. That source lists the 2013 Carrera S at 68.2 dbA at 70 mph.
In a perfect world, these cars would be as loud as they are (for the buyers who like then that way) an for the rest of us, there would be a switch to turn on an active noise cancellation system to quiet the car down on less than perfect roads. That way, every one wins.
#47
I also have a 535i (F10) and find the road noise in my 991.2 C4S higher -- unsurprisingly so. I find the noise level appropriate for a sports car, but perhaps a touch too high to leave 3+ hour drives at highway speed with one's ears completely intact. OTOH, the sound systems in the new 2017s are noticeably improved.
There was a thread here, a while ago, on adding sound dampening material to the wheel wells. Quite the DIY job. After new tires and plugging up the symposer, I would look at that, perhaps?
#48
As to the sound systems, if you are at all concerned about db levels hitting your ears (I am) then using the sound system to drown out tire and exhaust noise, you might accomplish that, but you'll be sending 100 db to your ear drums in the process.
I'm sure there are roads in America where you can drive 70 mph and get a 70 db interior (that is what Road and Track tested the car at), but where I live isn't one of those areas.
#50
continentals seem to be the quietest, the pirellis are definitely the loudest and michelin super sport seem to be in the middle but with the best overall performance. I wonder how the new 4s is.
#51
Hello again,
This may be extreme, but if you are so inclined, you may be able to get anywhere from 2-6 dbA noise reduction with an interior dynamat treatment. This does involve some interior work, however, and may not be cheap. A high end audio installer should be able to advise of options for interior sound deadening treatment.
#52
Hello again,
I've dealt with my ear condition since I was in my mid 30's and have done pretty well by limiting how much high volume continuous noise I expose my ears to. Clearly, I am in the minority in the Porsche world though (sensitivity to noise), so I do what I can to be able to enjoy the car and protect my hearing.
I've been riding Sea Doos since 2003. That is where I first noticed the impact of loud noise on my hearing. So, I wear -30db ear plugs when I ride. I get off at the end of the day and don't hear anymore ringing in my ears than I did before I started out - which is a good thing. So, on the worst of the roads at speed over a long drive, I'll do similar, but with less noise defeat, cutting about 10 db from the tire roar on the highway and just enjoy my car.
#53
I got my new Michelin Pilot 4S tires installed last week. Before replacing them, I used the Decibel10 app on my iPhone to take a DB reading of my older P-Zeros on the car. Note that the PZeros still had reasonable tread left before the wear bead with 4/32" remaining at the most worn spot, but I was replacing them since they seem to be getting too slippery despite being only around 18 months old (based upon the dates on the tires). I think here in central Texas we probably get more heat-cycling effect than many places.
I knew the new tires felt better and sounded quieter, but I'm pretty surprised by the difference I got in the readings from the Decibel10 app. I can't say whether these DB numbers are completely accurate, but the comparison should still be valid since the readings were taken with the exact same app on the same road section under the same conditions: cruise set at 70mph, reasonably new asphalt (the new kind made for better wet traction), flat section with no bridge seams, AC off, fans off, car in Normal, PASM off, radio off, windows up, similar temperatures, phone place in same position and mounted the same.
How much is due to new vs old (tread depth, heat-cycling hardness), and how much is due to the tire themselves I can't say (I do think the PZeros had gotten somewhat hard), but here is the before with the old PZeros on the left, the new Pilot 4Ss on the right. I'm very pleased! So far I can say the turn in and line holding is much improved and ride feels better too, so nothing but wins for me.
Johndani (11-15-2020)
#54
#55
It lists a 2016 Carerra S at 71 db (70 mp/h) and a 2012 BMW 535 (my last car) at 61 db. So the numbers are different in my test (BMW 83db, Porsche 93db) on my test road, but the difference between the cars (around db) on the same road is about the same (~10db). I think someone has posted that that a 10 db difference is a doubling of the sound pressure. That is consistent with my impression of the sound difference.
I did a test this morning in my 991.2 C2 MT with factory 20" Pirelli PZero's cruising at 70 mph in 7th gear with windows rolled up and fan turned off. Highway I280 in California has both concrete and lower noise rubberized asphalt sections. I measured 74 dB(A) on the concrete and 71 dB(A) on the rubberized asphalt, using the NIOSH SLM iPhone app. Rolling the driver's window down increased noise by about 7 dB(A).
#57
Michelin Pilot Super Sport N 4, I believe. Designed to meet Porsche's specs. Very quiet indeed compared to the last set I had on, Continentals. My nest set will be the same.
#58
I find the PZeros on my Carrera are fairly quiet on most pavement, and I only get a lot of tire noise on rough pavement.
#59
Hey Valvefloat991. Last Tuesday pulled over for 83 mph in 60 mph stretch. The car indicated the same speed as the HP's radar. From reading threads on the subject I purposely was driving 3 mph over my desired speed. Lesson learned
#60
