During my drive in the San Juan mountains yesterday, I noticed some odd behavior when coasting down hill. I have a 991.2 C2 (with MT). After downshifting for some steep declines, I felt the expected engine braking. But after coasting for a bit, suddenly the car felt like it was no longer in gear, and it sped up. This happened repeatedly, and in different gears.
Is auto stop start enabled? If so, turn it off. Auto stop start also enables coasting mode which disconnects the transmission and shuts off the engine when there's no throttle application.
However, OP states that he has a manual transmission. Coasting (aka gliding) is only a PDK feature. It requires the clutch to release and the car can't do that on a manual tranny.
The only time I've felt this sensation in manual cars, and it was rare, was when coasting and the RPMs finally get down to a level when engine braking stops and the car's engine is starting to engage forward motion again even with the accelerator not being pressed. This requires a drop to near-idle RPMs to happen. In any non-downhill situation this is where the engine would start lugging, but in a downhill it has gravity to help with the load..
Thanks for answers so far. I had Auto-stop disabled (I checked twice). And I felt this sensation even when the revs were moderately high (I can't remember what the tach said, but the engine noise was fairly high).
I have a 991.1 GTS with a manual tranny. I have long been suspicious the throttle is being opened under high vacuum conditions since the braking is less than I have experienced in cars with mechanical throttle linkages. This behavior has been noticed when using engine braking that suddenly decreases. Maybe the fuel turned on again as the rpm decreased. So much simpler when we mechanical linkages.
There's a system on all modern cars called decal fuel shutoff. That means that when you take your foot off the throttle and are coasting, the engine management system stops injecting fuel into the engine to reduce fuel consumption.
If you continue coasting, and the engine rpm falls, the fuel turns back on at some point to make sure the engine doesn't stall. That rpm varies, but it's usually around 1000. This does not usually create a major change in engine braking. The fuel is usually turned on gradually to make this transition nearly seamless. ON my 911.2 MT, I have to be paying attention to notice it.
Thanks, guys. I noticed this again yesterday when driving to southern AZ on hwy 77, and crossed the Salt River (awesome, twisting descent and then climb with lots of 2nd and 3rd gear). I could definitely feel the sudden reduction in engine braking at times.
One more bit of data: coasting down the Catalina Hwy from Mt. Lemmon, mostly 3rd gear and between 35 and 50 mph, the key rpm was about 3000. As the car sped up and the engine hit 3000 rpm, it felt like the engine braking dropped off--not completely but the car speed did surge a bit. And this was very repeatable.
