Project "Baby 911R"
#61
I've been debating to get DSC too, I have Bilstein B16 Damptronic, but haven't came across reviews on b16 + DCS yet. Currently, in sport and sport plus, it is way too hard as daily drive. Anyone has experience or input with this set up?
What's the difference between standard mapping and custom mapping? what are the pro and con?
#62
Also keen to hear what OP thinks of the Akrapovic.
#63
Former Sponsor
Not sure I fully understand your second question. We offer a standard tune file that is more than sufficient for over 90% of our customers, but the tuning software is always there to use and make adjustments as needed/wanted.
~Jordan
#64
Hi Jordan,
I think I've seen B16 + DSC on 997 posting awhile back but mostly for track use. Haven't came across for 991 and for daily use. if you come across 991, please do share. I would like to know if the DSC can improve the comfort of B16 ride quality under normal mode. Is the ride quality similar to factory pasm in normal mode?
For 2nd question, Titleistaddict87 mentioned that Larry Cable send him Larry's custom maps which he would highly recommend over the standard. So I was wondering what are the difference?
#65
OK a little Off Topic here.
So I was thinking about this thread and the idea of a "Baby 911R" and how to actually buy one rather than build one. If the idea is to get back to a "driver's car" like the 911R then possibly a good starting point is the current base Carrera. Everything I have read indicates that it feels the most like past cars.
So, start with a base Carrera and lets call it the 911 Club Sport. Porsche could offer it with Radio Delete, A/C Delete and Rear Seat Delete. Add the cool lite weight door pulls that are available on the GT3/4, give it, 20" Carrera S wheels, six piston S brakes (PCCB as an option), Sport Design Mirrors, Sport Chrono and PSE and even SPASM (FAL as an option), the GT Steering Wheel, Short Shift Kit from the GT4 and then, remove most if not all of the sound deadening material and, this is a BIG one, give it lower final gearing. Sure top speed would drop but I'll never see 150 let alone 180. I'd much rather be able to wind it out in the first three or four gears on the freeway without fear of going to jail.
I'm sure they could "tune" the base engine with the smaller turbos to produce 15-30 HP more than the base but still less than the S and you still wouldnt be able to get the PDCC or RWS like on the S. They should be able to price it right between a base and an S and still make a profit since they are removing items like AC and the radio and rear seats and belts.
Now back On Topic - OP have you considered removing sound deadening material in your S to save weight?
#66
Yeah, I don't think so. Porsche left 20whp/tq on the table because they couldn't figure out how to size the headers properly? Please post before & after dyno.
#67
As for the Akra, ran into a small problem with the install and waiting for new Torx bolts before I can complete. Hopefully they will arrive soon!
Hi Jordan,
If I understand it correctly, Porsche is more concerned about the balance between reliability and performance not outright performance so completely expected from my point of view there is more power to be gained.
#68
On the 2.7 cars, SC's, 3.2 Carreras, and 964's, there are gains to be made from headers -- but only because these cars didn't come from the factory with headers.
#69
Well, yes. But headers aren't a wear item or a source of reliability problems (well, unless we're talking about a Ferrari 355). Porsche can make the inner diameter and collectors any way they like with no effect on reliability. I'll gladly eat crow if someone posts a credible before & after dyno showing that bolting on Fabspeed headers produces 20 RWHP & torque.
#70
It's also a packaging and emissions issue as well. These motors are not tuned to the last hp, Porsche always leaves a bit more as they didn't know when they designed it originally for the 997.2 that it would be replaced after the 991.1. Checkout the GT3 forum and what Dundon has been able to achieve. They also have a GT4 setup and are working on a 991.
https://rennlist.com/forums/991-gt3-...group-buy.html
As for the sound deadening, I've tried to order my last two porsches without it; no go.
It's a nightmare to scrape off as the modern formula is sprayed/baked on and is very adhesive while getting into every nook and cranny.
#71
Basic Sponsor
Here is data from a Base C4
Here is data from a GTS, as well as 3rd party dyno results from fellow forum member MagicRat
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
#73
No one's mentioned perhaps the more transformative mod of all: carbon fiber wheels...
If your willing to spend $10k on a Akraprovic full ti exhaust (with negligible performance increase), then ~$15k or so for cf wheels isn't out of line (especially if you sell your OEM wheels)...
#75
If u dont mind my asking, how much for the exhaust? I seem to remember getting a quote of around $10k and that's just for the parts. Thanks in advance.
