Porsche 991.2 Carrera GTS Announced
#108
So configurator question - the wheel and shift **** are alcantara. Looks like if you choose the sport gt (smaller) wheel at no charge - the picture is leather wheel and leather shift **** - but there's no text on it. Interestingly the brushed aluminum shift **** appears to be with leather boot instead of alcantara also. Does one have to order brushed aluminum **** to get leather boot?
#110
That Alcantara GT Sport Steering Wheel together with gear lever/selector/boot in Alcantara is a $910 option on non-GTS models. And by selection that leather GT Sport steering wheel option on a GTS, I think it merely delete or revert that Alcantara option.
#111
My conclusion is that, one cannot differenciate or pass a blind test on the presence or functioning of real wheel steering.
It does shine in crowded parking lot; definitely reduces turning radius.
Other than that, just adds weight.
#112
Originally Posted by fanporsche
Seems that, like me, most are skipping the Rear Wheel Steering option in the GTS. What are the reasons?
I am still in doubt...
I always park in isolation so rear wheel steering not very applicable for me. I do track my 991 and would choose it just for that reason alone.
#113
Honestly the car was developed with RWS, I would'nt leave it out as it does significantly change the character of the car on any given turn and makes turn in that much sharper. I've got it on my build.
#114
I had the Real Wheel Steering option on an BMW 6 series couple of years ago.
#115
#116
I find it interesting that many of the reasons provided for having RWS as a must have option are similar in nature to the reasons given for why AWD is a complete waste. Just saying.
If I were deciding on whether to check the box, not sure I would just for a few added seconds for casual track days. One of my favorite things about driving on the track is being able to throttle steer the rear wheels through and out of corners. Seems like this trait would essentially be negated with RWS. But there is certainly an element of coolness to it that I would love to experience either way.
Question: Can you actually see the rear wheels turned (albeit ever so slightly), when parked for example? That would be pretty cool too.
#117
#118
Nor does AWD seem to be a problem on the AWD variants. Just pointing out that each has added weight, complexity, probably improved track times or at least confidence, arguably takes away some driver involvement, etc. But one is a must have option, the other is often scoffed at.
#120
