A mouse eat my Backup camera wiring
This is funny and ironic ... I had my backup camera malfunction yesterday and I thought this must be a small issue with the camera itself. So I went to the dealer for inspection and they found traces of a mouse poo and bites around the area. The sad part is that porsche do not sell wiring harness in pieces and the co-axial wire for the backup camera is only part of the whole car wiring harness
the dealer kindly searched for remedy within VAG products and found a connector that may work between the cut and connect the co-axial wire.
Talk about the most expensive mouse bite ever
The harness itself would cost 6K$ if the connector didn't work ... that is not including labour work of replacing all harness ... I might just leave the camera off and move on lol.
Repairing the damage could turn out to be the least of your problems if you can't figure out a way to keep the rodents from returning to your car when you bring it home.
Lots of recommendations on how to do this on the interweb. Good luck. And get a cat.
DaveGee
DaveGee
lol thanks guys. The funny part is that I have like a dozen cats around the house which I didn't plan to raise initially but they are kinda part of the house now. Yet this happens.
I am kinda skeptical that this might actually be a kitten not a mouse. The technician said he saw mouse feces. I didn't. and apparently the traces on the dusty intake shown claws .. now I think of it, It actually might be a kitten.
It's rodents, not cats. My son had wires in his Acura chewed through by squirrels. Apparently manufacturers are using vegetable-based (soy) coatings on wires in an effort to increase biodegradability. It's a known problem.
One of the advices on the intwerwebs is to keep dog/cat food away from cars. That is really funny since I assume the rodent should've eaten that food instead of a soy wire lol.
Wife's Cayman had a Check Engine Light come on...rodents chewed through a wire and damaged a few others. My 88 911 had the front oil cooler rubber air dam chewed up...it was only about two years old. Parking outside sucks.
I had an ongoing battle with Pack-Rats chewing my telephone wiring, which ran in a small crawl space under my summer home. It was odd it was only the telephones wires they liked, maybe soy based insulation as noted above? I ended up putting in a metal conduit run to protect the wires.
