Lord, is the 991.2 a fast car!
#121
One reason why the 2017 S might beat the turbo-turbo and GT3 is aero. The is no way to prevent the turbo-turbo from deploying both front and rear spoiler, and the GT3 is fixed wing. If you are doing a timed anything where you don't actually need the downforce you just suffer the additional drag.
According to base data the 2017 S pdk is also 300 pounds lighter than the 2016 TT. Some of that is eaten up by rear wheel steering and the like, but some of the difference will remain, again for the active aero to start, and AWD. cw coefficient is given as 0.31 versus 0.30, and the winder TT body will add more drag. So even before any of the active aero does anything the TT is heavier and has more wind resistance.
PDK might also have been upgraded. The software they mess with all the time.
#122
Viper ACR "suffers" from Aero. The problem here is comparing track times for street cars. As in Viper's case, 0-60 and top speed are handicapped since it has aero that is designed to keep the car glued to the track. That much aero is worthless on the street for any driver.
#123
Basic Sponsor
Big gray area, really depends on your dealership and your relationship with them. Some won't let you use an aftermarket valve stem, others will have a full performance shop selling and installing aftermarket components. Luck of the draw I guess.
That's one VERY good question. I couldn't connect emotionally with the .2 because of how quiet it was. The PSE "might" fix the exhaust note but I heard zero induction noise during our test drive.
I just can't see how it's going to ever sound better than the 3.8L GTS. I's a super nice car, fast and efficient but I need engaging, not fast. Some of course need the speed.
Initially I wanted an E92 M3 because of the growl of its V8 motor, drove the new models and had the same issue as with the .2, faster more efficient but not engaging.
When the DD has to be replaced I might give the 991.2 a second look or try a Cayman, we'll see...or look for a 2nd 991.1 GTS with a decent mileage...all good problems
PSE
Non-PSE
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
#124
Of the two, I actually think the non-PSE sounds better, more natural and less whizzy. But neither sounds good IMO. I just think people have to accept that the .2 cars aren't going to sound very good relative to the Porsches of the past. Not the end of the world.
#125
Instead of piping randomly picked input sound, or playing on the stereo something pre-recorded, somebody should smarten up and place a quality microphone into a good sounding place (I suppose in practice that means multiple mics for user choice) and play that over the stereo, after making sure some speakers are in the right place for the illusion.
I don't think the 991.2 can ever satisfy those who like lots of farts and burbles. I bet there is great potential somewhere around the intake manifold for those who like the mechanical hammering blending into a scream.
This probably isn't as terrible for warranty issues as it sounds. Robust microphones are a long-developed art, think air and space travel. There is plenty of bandwidth on existing computer busses around the upper side of the engine. You don't need high end microphones or A/D converters since the sound doesn't touch particularly high or low frequencies. As long as proportional accuracy is there it would sound great.
Natural sound? Well looking at what Porsche did with the bad sounding and obnoxiously loud 718 I'd rather have choices.
#126
In situations where you don't want max torque but want linear control of how much you're putting down, it's hard to beat a NA motor.
#127
To the extent that any track can be summed up by a single quality, WSIR is a momentum track -- just a very fast one. My 2400-lb car hits redline in 5th at 134 mph, and only has 272 (crank) hp to get me there. But I'm quicker (on real street tires) than the 991.2's posted lap time. And the 991 GT3. And a lot of other high-horsepower 911 variants. My low weight means I don't need to slow down as much and can carry more speed through the sweepers.
For what it's worth, I think the 991 GT3 would be quicker around Willow than the 991.2 Carrera S, most of the time. Different laps on different days can vary a lot. Ambient temps make a huge difference at Willow Springs for my car.
Now, at a certain point straight-line speed and horsepower will make a difference. I match a pro driver (Pobst again) running a record lap in the 918 for the technical half of the track (turns 1, 2, 3, 4, and 5) -- but he destroys me on the back and front straights.
Check out my red speed line in the data comparison:
(Even in 8, I'm a tiny bit quicker than the 918.)
My car is a 1972 911 tub with a 272-hp 993 engine in it. I know the track very well.
#129
#133
[QUOTE=JackOlsen;13695589]Ha! That's me.
But (thanks to Porsche) I have gotten a little bit of experience with the 991.
QUOTE]
Great postings!
Now for a question.
If you could own just one fun Porsche, would it be the 991 911 R or your 72 S?
QUOTE]
Great postings!
Now for a question.
#135
