Question about wheel nut torque at my local tire store?
My local tire store just removed a good size nail and put a patch on the left rear P zero. Service was complimentary but I gave the tech a $20 tip for being careful not to scratch the rim. I did not think to ask him about wheel nut torque as he used the air hammer to re-install. I know the torque recomm is about 120 so my question is what the standard 'default' setting is at these tire stores. I can't imagine Porsche wheel lugs/nuts would be more 'fragile' than any other manufacturer. OTOH I would imagine tire stores would have a tendency to over rather than under torque. Thoughts?
Jim
Jim
http://www.porscheownersmanuals.com/...carrera/6/236/
Tightening torque for wheel bolts: 160 Nm (118 ftlb.)
Never ever let them rattle them home with the air impact wrench.
Received 1,679 Likes
+991
Those wheel bolts are now probably torqued to 150+ ft-lbs. Back in the day, with Porsche's aluminum lug nuts, an impact wrench would split the lug nuts occasionally resulting in the need to carefully drill/dremel-out the collet. Now, with lug bolts, a impact wrench might strip the wheel hub.
Jim
Jim
I would not be comfortable with this, at all......
Jim
Jim
Thanks everyone for the thoughts. The wheel will be coming off again in a month or so at the dealership as they continue to try and figure out the ebrake issues on this wheel.
J
J
Received 5,413 Likes
I'd ask for my $20 back. Don't wait a month to get this addressed at the dealership.
I just had some tire balance shenanigans from my go to discount tire center. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Went in for a slight vibration and asked for them to check the front wheels.. After reinstallation going home the vibration was 100% worse.
After checking torque ... I noticed when feeling the tread that it was a bit ruff and going in the wrong direction to be smooth. Here they reinstalled the tires on the wrong side of the car.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
After a quick switcheroo back to nice and smooth no vibration.
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
