Saving weight!
Old 06-29-2016, 01:17 PM
  #31
997s07
997s07's Avatar
What a fun circle jerk. You guys enjoy yourselves.
Old 06-29-2016, 01:25 PM
  #32
Jabs1542
Jabs1542's Avatar
I apologize for contributing to the humor, frankly I think the Op already got some really good suggestions:
Lex offered near zero cost alternatives,
Gbree offered some real track savvy weight savings gains, and
R_rated reigned the reality of just what you can expect.
After all, the car weighs ~3300 pounds and 100 pounds is a 3% change. Getting your turn in correct so you can track out fast will make MUCH more of a difference than 100 pounds ever would - talking lap times here.
Old 06-29-2016, 01:43 PM
  #33
LexVan
LexVan's Avatar
Received 5,402 Likes on 2,513 Posts
On a Carrera S, our cars are about 8.25 pounds per horse power. So if you can reduce the car by 165 pounds that's like picking up 20 hp. Easy to do with the things I mentioned. And free.
Old 06-29-2016, 01:47 PM
  #34
Roosell
Roosell's Avatar
Hey, lighten up sir!
Old 06-29-2016, 04:30 PM
  #35
997s07
997s07's Avatar
Right. Thanks.
Old 06-29-2016, 04:56 PM
  #36
gbree
gbree's Avatar
Originally Posted by LexVan
Post #3 and post #4 are all over $10,000.........right?
If you can buy a 911, $10,000 shouldn't break the bank, should it?
Old 06-29-2016, 05:11 PM
  #37
Porsche_nuts
Porsche_nuts's Avatar
Received 1,184 Likes on 711 Posts
Right. Thanks.
Old 06-29-2016, 05:21 PM
  #38
NoGaBiker
NoGaBiker's Avatar
I reduced 100 pounds by:
1) draining the washer fluid
2) only run with a 1/4 tank fuel
3) remove owner's manual
Free.
I also fill my tires with helium.
Let's see: washer fluid is probably a pint but let's say it's a quart. That's 2 pounds. Gas is 6# a gallon (lighter than water) so 3/4 tank of it is what, 12 gallons? 72 pounds. So you must have the hardcover version of the owners manual for it to weigh 26 pounds.
Old 06-29-2016, 05:46 PM
  #39
LexVan
LexVan's Avatar
We have at least a gallon of washer fluid. Probably closer to 2 gallons. So about 16 pounds.
And the helium filled tires.
Old 06-29-2016, 06:00 PM
  #40
NoGaBiker
NoGaBiker's Avatar
Fill the washer tank, coolant overflow tank and 3/4 of gas tank with helium then.
Old 06-29-2016, 08:53 PM
  #41
Dewinator
Dewinator's Avatar
Even better, go with hydrogen, it's lighter still.
Old 06-29-2016, 09:24 PM
  #42
Jabs1542
Jabs1542's Avatar
Isn't that what Firestone was using in the tires for the Ford Exploder
Old 06-29-2016, 09:31 PM
  #43
Dewinator
Dewinator's Avatar
It worked for Takata to save weight in the airbags! What could possibly go wrong?
Old 06-29-2016, 10:12 PM
  #44
titleistaddict87
titleistaddict87's Avatar
Hahaha, I'd like to hit the track but need to convince the wife to let me go. Backstory is one of my close friends almost died in a track accident 10 years ago so it's a sensitive subject. Broader perspective is I'd like to lighten the car in hopes of making it a little more responsive. I can't believe that the S engine is the same as the GT4 engine given how revvy and happy the GT4 is to go fast and rev. I feel the S needs a little more revviness to it if that makes sense and with a 300 lb weight difference between the two cars, it's substantial so a little less weight should be good all around.
Originally Posted by NA430GTS
Very excited you posted this! Why? Because it sounds like you are hitting the track soon. Spill the beans, man. What's going on here!?!?
Old 06-29-2016, 10:14 PM
  #45
titleistaddict87
Where does one go about getting helium for the tires?
Quick Reply: Saving weight!
