Hesitation and rough idelling
https://youtu.be/cRRKoAUirBo
Hello, just curious if anyone else is having similar issues? So far the dealer has tested the vacume system for leaks and it passed. Also fixed the speed sensor depth by adding a spacer (porsche recemended fix for hesitation) the heaitation is very evedant and always there unless driving fast then it just disapears.
2013c4s manual
Thanks. Hope to get some feedback.
2013c4s manual
Looks very similar to when I had my throttle valve go bad. Does it have trouble holding a speed with cruise control on?
At my dealer they showed me with the bumper and intake channelling off, you could see the valve shake. At high throttle settings, the valve is basically parallel to the airflow, so if it's shaking it doesn't really affect the airflow much.
Even the best and reliable gas stations get water in the gas once in a while. If all fails, flush the gas tank and get new fuel. If it was the fuel, use your cc receipt as purchase proof and send the gas station the invoice if it's not covered by Porsche. I went down this path before, it was a BMW. Replaced fuel pump, fuel injectors, fuel filter, and checked vacuums. It turns out to be water in fuel. I only gas premium.
I will ask them about it. It has been in twice but seems like they did not do a full analysis of the situation. it's going back in on the 21st. I can keep you guys updated on the outcome. The car is still under warranty.
Exactly how mine was. Since I have PDK, I also had very abrupt shifts too since he computer couldn't get the RPM just right when it dropped the clutch. But yeah in a gear it would bog/surge/bog forever. Eventually when it gets bad enough you get a red engine fault "reduced power ok to drive on" or something message on the MFD, and some other faults. When you get that you get like zero power, and have to turn off/back on to get the power back. I had to pull over and restart like 6 times to get to the dealership.
+1 this may be a fuel issue, and +1 on checking-out the TB. Easy enough to get to the TB.
