Auto stop start issues
[QUOTE=Dewinator;13366467]Coffee cup low would be way too readable, it'd be more like "Caution: Check remaining drink space in caffenated beverage utilization area."
You are right!! Porsche should also have a politically uncorrect message: "Caution your Miles till Empty exceeds the Maximum of 350. Drive faster or sell your car"
Here's a good one: http://www.batterymart.com/p-battery...FQJsfgodvBAOjw
Interesting they turn off the *** in this circumstance. Must be a big draw on the battery every start.
I checked the battery with a multimeter. It seems a little low at 12.04 after leaving the lights on for a few minutes. It didn't drop below 10 volts on startup. Should I replace it? If I do replace it will the warning sign go away or will it have to be "reset" by the dealer?
Neil,
I had the same happen to my 13 C2S a few days after I bought it, it really freaked me out so I took it in for a PPI, the guy who inspected it said I had a lot of messages and he also like others have mentioned said that the battery was low, he reset the messages and I haven't seen that since.
Neil,
Hi everyone.
Don't want to highjack a threat but didn't want to start a new one. I've only used the Auto start/stop on the day I bought my car (2mo. now) Since then I have always left the button pressed/lit (disengaged) today I decided to change my display after reading some posts about different display options i.e volt, compass to show speed limit, etc... I also decided I wanted to try out the auto/start stop while in the city. When I came to the first stop nothing happened? I thought maybe I wasn't at the light long enough, next light nothing again (car still running) and then a I got this next to the time (see pic) I don't have the button on (see other pic) and the rpms go to 500 when coasting. Did I change something on the display that would disarm the start/stop even if the button is "off"?
I believe there are a few factors that could cause it to be disabled before the system is ready function. Looks like your oil temp might be a little low or the car is just warming up from being off for a time. If there's a large draw on the battery the feature won't activate as well.
I think it's described in the manual.
This is freaky when if you have PDK.
Thanks for the links. I was hoping it was the oil temp so just took it out for a longer drive, oil was over 200f and still didn't work. I didn't have the A/C on max but I guess I'll have to try it with the A/C off and see if that works. Not sure what a "normal" battery volt should be so I don't know if that it?
