Auto stop start issues
Hi Guys,
I was driving my car about a week ago and this warning came up. It comes on every time I start the car. It doesn't seem to effect the cars operation. I am now out of warranty, but did notice my stop start function was NEVER engaging. I brought this to the attention of my service manager(when it was under warranty) and they said everything is fine. Although I don't think they even looked at it.
Any thoughts or has anyone else ever had this happen?
I actually like the "glide" portion of the feature but found the stop/start portion annoying. I mostly left it off but did put it on from time to time. In the last year I noticed it almost never engaged. That is when I called it to the attention of the SM.
We had this happen on our '15 Range Rover. Turns out the battery needed to be reset. The computer thought the battery wasn't holding enough charge to enable the ecostop feature. See if it's the battery charge.
It does sound like a battery issue. Neighbor's 2013 991 had the same message and I believe it was cured after a battery swap.
If that's the case, you should definitely push on your SA to cover this. A letter to PCNA stating how you previously brought the issue to their attention but didn't get any love will probably help, too.
I think so... the dealership has started reporting that my 2012.5's is weak, it seems like the alternator rarely goes into low-voltage operation during acceleration or cruise anymore, and when I plug in the trickle charger, it seems to charge for a long time. I'll probably have to put a new battery in this year.
