Solution to GTS wheels cleaning
#34
Black GTS are a Matte finish and will easily stain so coating them early on is a good thing. I think using Dawn I'm a test spot is a good thought, just proceed with caution. It's PH balanced but it will strip wax finishes off so it's much more aggressive than normal car wash soap...
#35
#36
#39
How would I know. You should have a sealant on your wheels. That's what makes cleaning them so easy with warm soapy car wash soap & water. My Sport Techno wheels are coated with Optimum Gloss Coat.
If you don't want to go high tech nano coating like OGC, use RejeX Wax. Very good. Easy to find. Cost effective.
#40
#41
During the driving season, after washes, I also use the Armor All Outlast wheel protectant spray.
#42
your wheels are not matte right? so this opti coat is prob not an option for the GTS wheels
#45
OCG is fine - it's a coating and will give you protection.
I use a Kranzle 1122T Pressure Washer, P21S Wheel Gel Cleaner, wheel woolies and the Microfiber Madness brush referenced above using a separate bucket with car wash soap. Then I rinse off the wheels and use Adams Detail Shine for a final wipe down clean up. Wheels are perfect for the first 100 feet before I need to brake and then they need to be cleaned again...
