Speed limit display in PCM
I took a quick trip from Boston to New York and back over the last couple of days. A couple of beautiful cruising days with the top down. A lot of fun. But somewhere along the line, I realized that the speed limit display was only in the MFD and I seem to remember that it used to also be shown in the PCM, at least while navigation was active. Am I crazy, or did I change a PCM setting without realizing it?
MFD - yes. PCM - not that I am aware of
Received 2,235 Likes
It will show up on the PCM only while navigating and only in certain modes. If you are in full screen, tap the block at the top to split the screen and the speed limit will appear.
That's it!! That's what I remember. The split screen took too much real estate from the map, so I switched to full screen a while back. Thanks for that.
