Jack pad?
Hi Guys,
I picked up a screw in my right rear tire, and I would rather remove the wheel in my garage, and take it to get repaired, instead of inflating it and driving the car. What do you use as a pad for the floor jack?
Thanks!
Thanks!
Hockey pucks, NEIN!
Careful, hockey pucks lack full rigidity and can cause your floor jack to lag in fully repositioning squarely under the jack points. This can cause a roll to the jack and your car can fall off the jack. This can cause damage -- don't ask how I know.
You must be joking. The no way a hockey puck will shift a jack, unless the the jack is not set properly. Set the jack at 180 degrees to the jack point and there is no way it will shift.
What am I missing here.
I have lifted my 991.2 with my floor jack and my lift. It takes careful placement of the jack pads, but was totally doable with out any other pads.
Am I taking careless risks not using a special puck?
