PDK shift pattern change
The way it was explained to me is that it's supposed to go in the direction of the momentum the car is taking you. So when you go hard on the breaks into a turn you're moving forward and hence downshifting is pushing forward. Likewise when you're accelerating on say a straightaway you're pinned back and up shifting would be pulling back.
Frankly I'm surprised that porsche didn't get this right. I would 100% switch if it were possible.
Not making it user-configurable is the real sin. The need for the owner to configure the car to match the behavior of other car(s) they may own should have ended all debate at the meeting where the decision was made.
I avoid using the shifter precisely because I have gotten it backwards before. Not good, especially in certain situations.
Not sure if reversing would help (i.e. maybe it's just me and I would still get it wrong sometimes), but the paddles seem completely intuitive to me so I would stick to using them regardless.
If you think the reversed shifter pattern is bad, just be thankful they got rid of the tiptronic style buttons on the first gen PDK!
I think the direction for shift up and shift down should be standardized, the way manual transmissions are (okay, the 901, 915 and G50 boxes have some differences). You go up through the gears working from left to right. Even those who drive from the right-hand side of the car use the same basic pattern. Try to imagine what it would be like if some cars had the gas pedal on the left and the clutch on the right.
To me, when Porsche realized they were going to adopt other manufacturers' shift direction with the 991.1 GT3, however long that was before it was introduced, all their PDK gearboxes going forward should have had the same shift directions. I imagine there are many folks who have a 991.1 GT3 as well as another Porsche with PDK- and Audis, BMWs, VWs and so forth. We could go back to the Porsche annular disc brakes, the Porsche synchronizers up until the G50. They are stubborn, for sure. But, as for being stubborn about the rear engine location, I will happily eat my words.
I thought about changing to a GT3 Shift Lever, but it's something like $700.
Perhaps a 991.2 Lever might be cheaper.
Naturally, would need to compare the 2 levers to see if they are interchangeable.
Imagine if a manual transmission reversed the H pattern front to back... first would be back/left, upshift straight forwards to 2nd, upshift back and to the right for 3rd...
Anyone care to speculate about how difficult a reversal of the shift pattern might be on the original PDKs? I'm guessing more than software is involved, but I'm not an engineer or a mechanic.
If it's a relatively easy switch, I'd be up for it.
I have only tried using the shift lever to shift a couple of times in the 18,000 miles I have put on my 2015 Carrera S with PDK . . . mostly after reading all the bitching on this list. I prefer both hands on the wheel and just click the Sport Wheel paddles with my fingers.
Compared to my three other sport cars with manual transmissions, I was surprised at how quickly i adapted to the PDK "girlie man" automatic.
