Question: Brake pad wear on new rotors.
I just replaced my front rotors yesterday with new OEM. The old ones were very worn and cracked. I am prepping for a track day and installed my 1/2 used-up Pagid Yellow RS 29 pads. I took the car for a 1.5 mile test run with ten or so 45 mph to 10 mph braking hits. Not enough for a proper bedding in, but it gave me a wear indication for the pads and rotors.
As you can see from the pic the "inside" of the pads are barely rubbing on the rotors. Do you think the pad material will quickly wear away to create an even wear pattern? Or do they have to be replaced? I hate to give up on these pads because they are only half worn and are so expensive. But I can't live with half the braking force because of a oddly worn pad. And I certainly don't want to ruin the new rotors.
Track rats, what would you do?
![](https://www.fototime.com/158770AA607BD2D/standard.jpg)
hows the car feel under braking. I'd try to do some more street driving before the event, and if it improves, I'd not worry about it. If it feels crappy under braking I'd probably look to another option.
worst case, sand down the old pads on a bench till they're flat.
But I think I will do some more street driving and if it doesn't "flatten out" I will do as you suggest with the pads...take off $20 or $30 worth of material (!) and see if that gives a better wear pattern on the rotors.
Didn't you say those pads where about 1/2 used? I'm not that smart on brakes but when I replaced mine a couple weekends ago, the pad thickness on the new ones was about twice that on the old ones, which were down to the point where the pad was about the same thickness as the backing. I thought I read somewhere that you don't want it any thinner than that for track use?
My Pagids are at least twice the thickness of the backing plate right now. Used, but not dead yet. My problem is getting them to mate squarely with the rotors.
Not that you asked, but to properly bed Pagid pads, it takes a minimum of three brake motions from 90mph to 20mph. If not, they won't bed properly until you hit the track. Also, I would advise a bit more braking distance until the above has been accomplished and they are track hot. You will feel it when its bedded.
You could take a micrometer to the sides and middle of the pads so you have three measurements across. If you don't want to take everything apart again and have the old rotors you can measure them. If it's excess it's easy to trim or shave pad material. Likely you'll be fine though with a little street driving. I typically rotate pads or swap between calipers so they're not matched pairs anymore when changing rotors.
Interesting tip about mixing up the track pads. I thought you were always supposed to leave them matched.(?) Do you randomly swap all four pads? Or just side to side? I like the idea.
Received 5,407 Likes
Brad, make a run to Augusta and Defiance, buy a case of wine at Chandler Hill, I suggest the Norton, and drive home. Pads and rotors should bed in.
