How does the pop and crackle of PSE work?
Originally Posted by Vise
You should hear it with an aftermarket x-pipe! The over run pops + crackle on downshift with my Cargraphic x-pipe is maniacal to say the least. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
darlinboy (05-26-2020)
Received 2,237 Likes
I did a search and did not come up with any answers and the function of the exhaust intrigues me.
Econ mode w/PSE ON - fuller exhaust note w/o pop and crackle![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Sport and Sport + w/ PSE ON fuller exhaust note with all the pop can crackle you can handle![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
So what makes the pop and crackle happen?
Fuel dump?
Exhaust valve remap allowing then to stay open longer?
Fuel dump?
So how is this maximum performance at redline achieved? During the power stroke, it is necessary to open the exhaust valve before the piston gets to the bottom of the cylinder. This will allow the excess pressure in the cylinder to escape just before the piston reaches the bottom of the stroke. The term "Blow Down" is used to describe this event.
Timing the exhaust valve in this manner assures no pressure is left in the cylinder to push against the piston on the exhaust stroke. Otherwise, there could be significant pressure pushing against the piston as it starts up the cylinder. This would require some of the engine's power just to push the exhaust out of the cylinder, thereby reducing its power output to the wheels.
As to how Porsche achieves this sound is just speculation on my part, but the easiest way would be to program the ECU in such way that a spark plug wouldn't fire under certain conditions, thereby allowing some un-burnt fuel to flow out to the hot exhaust. This of course would cause a popping sound not unlike the sound that a race car engine makes at lower rpms when un-burnt fuel vents out to the exhaust. Since this event occurs in milliseconds, I doubt that there would be any measurable decrease in the car's MPG.
