Techart vs H&R springs...
#151
#152
Techarts on 991.2s
Here are some pics of a 991.2s with rws and pasm... 15/8 spacer combo
#153
Looks perfect. Good post.
This was the look I was going for (same rims) but was way to low with H&R
#154
Premium Sponsor
All these cars are turning out really good! If anyone is on the fence about going with the Techarts feel free to give us a call and we can go a bit more in depth!
TAG MOTORSPORTS
866-793-5490 x1192
web: www.TAGMotorsports.com - email: sales@tagmotorsports.com
Authorized Dealer For: HRE, Vossen, TechArt, AWE, Bilstien, KW, Akrapovic, Capristo, Fabspseed, BBI, Vorsteiner, Milltek, 1016 Industries, BBS, Brembo, GMG, H&R, Pirelli, Michelin, Hankook & more.
TechArt & AWE Tuning's #1 Volume Dealer Nationwide
866-793-5490 x1192
#155
I just had my H&R springs removed (previous owner installed) and my car feels like a 911 again. It was way too low and stiff and now it’s road worthy and feels good around corners. My 2cents is that H&R lowering springs look great when the car is parked but the ride and handling aren’t worth the “stance”.
Ps: this is my 4th 911 and I have a racing history (F2000) so my tastes might be different than the reader’s
#156
My car already had the 20mm lower SPASM springs, and I still wanted to adjust stance a tad with spacers to bring the fronts out a bit and the rears just a tad more flush. I also have FAL (front axle lift) and decided to go with H&R springs and couldn't be happier. Do your research here with pricing, I noticed some vendors selling the H&R springs for double what I found them for online. I went with a huge reputable online source, I won't name names but rhymes with Fire Track.
The car handles better than before in my opinion, feels a tiny bit stiffer. Looks a bit better for my taste, with a gain of an additional 12mm drop (roughly a 0.5") over my already lower SPASM setup on all four corners. All four corners are now pretty flush with fenders, will take pics in a few days when it's all settled and I take one more final set of measurements. For now here is a quick pic from date night with my wife last night and a quick stop at Publix this morning, where shopping is a pleasure.
tourenwagen (07-18-2020)
#157
2018 991.2 Targa 4S PASM
H & R were to low changed back to stock immediately after seeing it sorry no pictures. Was only looking for slight decrease in height similar to the SPASM but this was to low. Front looked very low. Wheels cleared fender but on angle car appeared to be sitting on the wheels. Would need spacers.
After the fact research including this thread Techart would most likely have been perfect but wiil keep stock for now given the purpose of the Targa and other GT cars soon to be delivered.
I wish you had pictures. I am on the fence with adding springs on the Targa 4gts. It currently has the same wheel gap as my sq5. 🤦*♂️
#158
#159
#160
Originally Posted by stout
Great looking car. Metallic white, or plain? Or? Almost looks a bit like Geyser Grey (in a good way) in these pics...thanks for sharing them. Guessing you are running the bigger spacers up front?
Before anybody asks why I didn't just buy a car in a color I wanted.....this particular 991.2 was fully loaded with all the options I absolutely wanted including manual trans, just slightly used with 3k miles, plenty of warranty, front axle lift, rear axle steering, heated and ventilated seats, PSE, S-PASM, and on and on and on.
#161
Techart springs are made by Eibach to Techart specs, but Eibach springs are not the same spring. The ride height is similar, but the rate is different.
Techart worth the difference in price. Highly recommended
#162
I highly recommend Tecart springs. Mild drop and ride quality remains Porsche 911. Cornering is improved.
I don't have experience to debate the virtues between the 2 but I struggle with the "value" difference since there's no way there is any meaningful difference in cost to make - just an additional middle man and/or brand markup IMO.
#163
Do you have any details on spring rates?
Eibach makes springs for numerous small companies and tuners - not just Tecart/Porsche. Quite common in the automoive world and manufacturing in general.
The Techart springs are made to specs that allow for a small, but noticeable improvement in cornering. The other benefit encountered by Porsche owners of Techart springs, is an extended service life over "standard" Eibachs. The Eibachs are quite good, and would be my choice if I did not intend to keep my 997.2 C4S for many years.
Each of us, of course, choose where to spend our hard earned Porsche Dollars and where we will receive the most gain per dollar for our desired results.
#164
Have the TechArts on a 991.2 Carrera and they're much as everyone says: they ride nice & look good.
Downside is that their progressive rates, which make the ride a bit nicer around town, can overwhelm the PASM curves when the springs get compressed into the upper rate range, which seem to be designed with straight-rate springs in mind. This is a 2-8% of the time issue, most noticeable over a significant bump at speed that introduces porpoising—of which there are not many where I live. Adding DSC from TPC helped, but it seems they prefer H&R's straight-rate springs, and I have yet to drive a setup from Levitas I don't like. So, if I had it to do over again, I'd ask Tom or Mike at TPC for their thoughts on H&R's VTF setup, with variable perches. I wonder if Mike can specify the rates with that setup, as well. I suspect those springs, DSC, and a rear bar or maybe both bars might get pretty interesting. Add Cup rubber, and I suspect the car might be a nice-riding beast.
#165
Thanks the car is actually Guards Red, I have an autoflex coating on the car, essentially grown up version of plastidip with clear gloss. Was shooting for chalk, but it lightened up quite a bit with the gloss. It's got tons of orange peel in it, but it peels right off, and is supposed to last me 5 years or so.
