GTS questions
I had the same question recently. I got this response from Dewinator:
You'll notice when you up shift at or near redline, it is near instantaneous as well. The delay when you are driving slow is the computer has to engage the gear you have selected before switching to it, because it is prepared for a downshift. I.E you are driving around town in 2nd, the gear it engages on the odd gearbox is 1st so it can switch to it with only disengagement/engagement of the clutches because it wants to go fast. If you select 3rd, it has to change from 1st to 3rd before the clutches can switch you from the even gearbox to the odd gearbox.
Actually, I don't believe that's accurate -- there are other parameters changed by SPORT+ that can make a person want to use it even when not running to redline. Which is why I drive in Sport+ about 85% of the time. Most noticeable difference is the nature of rev-matching and burblefarts on manual downshifts. Loosening up PSM's traction control interference is fun for those times (no more than once a day, I promise!) when you want to break the rears loose a little bit on a 180 degree u-turn, which I have to do to leave my office and head east (direction of my home.) There's a median so I have to go up to the light, then u-turn and head back east. Goosing the throttle just right allows for some righteous tail wiggling!
He not only let me put it in sports plus but told me I wasn't driving aggressively enough. I know Porsche doesn't recommend the engine revs to go over 4000rpm during break in so I wasn't trying to redline it or anything, especially if this was the car I was going to buy! Incidentally, they're offering about 7% off sticker, good deal or not?
Like the OP said, he didn't push it since he may buy the car. My point was if the BA was giving test drives in SportPlus mode how many before him? How many drove it is SportPlus while letting PDK shift.. I was thinking out loud.
This post is detracting from the original question but I just wanted to clear that up.
According to a Silverstone instructor there is an (extremely small) performance advantage to CLs. They centralise the mass of the wheel more than 5-lugs (the bolts being the heaviest part of the wheel) and so fractionally reduce inertia.
I always thought CLs were for rapid tire change on the track (in the pits).
IIRC from the GT3, the shifts also got faster once the car warmed up. So if the car wasn't up to temp, shifts may legitimately have felt slowish.
For the CL's, once you have the tools and familiarize yourself with the minutiae, it's not that tedious.The special grease gets everywhere so wear gloves. If you're doing it yourself, get one of the HDPE wheel guides made by a rennlister. You'll need to have someone pressing the brake pedal when loosening or tightening when up on blocks. Most of us usually use a carpentry spreader against the seat and brake pedal for pedal pressure.
Received 5,413 Likes
I just test drove a 2016 GTS wirh PDK and have a few questions for owners:
1-I feel about a half second delay in upshifts even in sport plus mode between the time you pull the paddle to when you feel it shifts. Is that what you find too? Downshifts are instantaneous.
2-The center lock wheels are beautiful but concerned about their practicality. Do you need to go to a Porsche dealer to replace the tires or are there many independent tire shops that can handle center lock wheels? And how long do you find your tires last, especially the rears which I'm sure wear faster than the fronts.
3-Are center lock wheels more prone to get stolen? Have you heard of any cases of theft? Thanks for any replies.
Nope. Wrong. https://rennlist.com/forums/991/8250...ery-diary.html I did ask about break-in, and got the following answers: “for American customers, we must recommend you to keep it below 4200rpm, for everyone else we suggest use it as you normally would: careful while cold, then flat out.”
Here is a good read for you. Enjoy:
https://rennlist.com/forums/991-gt3-...e-s-mouth.html
Was the car fully warmed up and being driven hard, or was it a short test drive? When I drive off in either of my PDK cars, strolling out of the neighborhood, the shifts are a bit lazy. But as soon as the car warms up and I'm driving hard, they're instantaneous from then on. I've always assumed it's something in the programming.
Not crazy, just placebo effect or our inability to separate different elements of feedback we get from the car. In my RS5, when I put it in luxo mode and soften up the steering, shift points, throttle response, etc., I'd swear it softens up the suspension as well, but I know it doesn't, as it's not an adjustable suspension. It's just that changes in all those other elements impact the way the suspension is taxed and that feedback is what I'm sensing.
