display wil not keep settings
Hello All-
I was revewing the options for my display and discovered that a 4th line of information may be added to the display---I added "voltage" as the information to be displayed on the 4th line.
The voltage information will display for a day or two----then disappear. I have set with the vehicle running and vehicle in Stand-by key position. Again, the voltage information will display for a couple starts....then not display any more.
I would be interested if any of you have experienced this or better yet "solved"![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Cheers
Cheers
Are you using the same key each time you drive? If not, that is the reason. Set up the car how you want it. Then push the key memory button to save all of your custom settings to the specific key. Turn off the car and then repeat with the other key. Should be good to go then.
I was wondering why my seat, display and radio setting were different a few weeks after ownership. Here I was grabbing the second key.
![order](https://rennlist.com/forums/graemlins/order.gif)
