Violin case for 991 frunk
Old 01-16-2016, 09:54 PM
Duke I
Duke I's Avatar
The case is for a violin, right?
Old 01-17-2016, 03:33 AM
Porscheforever
Porscheforever's Avatar
Could you please measure the approximate dimension of your viola case, Brad? Thanks a bunch!!!
Originally Posted by BradB
Perfectly understandable question. My wife's viola case fits just fine in the frunk. Keep looking, there are plenty of cases that will fit.
Old 01-17-2016, 03:44 AM
Porscheforever
No luck so far, but will keep trying for sure. It's much easier if I can just find the right dimension.
Originally Posted by Vise
Man I love this place.
To the OP, see if you can find a music store that will let you test fit the cases before you buy?
Old 01-17-2016, 03:57 AM
Porscheforever
It's an idea, but...I prefer not to use the rear seat or passenger seat because it requires access space from the sides. Parking here is like parking in London where cars are lined up closely like sardines. It's much easier (and cooler) to access the baggage from the front
Besides, the expression of people of seeing me pulling a bag out while pretending to be a mechanic is priceless!
Also, I "don't think" it fits the passenger floor mat without tilting it vertically. The violin case is also very light and may cannon out of the windshield or fly into my face with sudden braking. C'est La Vie.
Originally Posted by LexVan
Set it on the passenger floor mat?
If you have a passenger, have her hold it.
I'd rather not put it in the frunk. Less finger prints on the hood and crest.
Old 01-17-2016, 04:01 AM
Porscheforever
Yes, it's for violin.
Viola can have the same length as violin, but it's generally about 5-6 cm longer (2 inches?) and a bit fatter / thicker. So if a viola case can fit into the frunk, a violin case can certainly fit - but I still need to know the approximate dimension to get the right violin case!
Old 01-17-2016, 04:08 AM
Porscheforever
A trombonist! Cool
Originally Posted by Slantnose!
Should try fitting a trombone in there...
...like installing a rollbar!
Old 01-17-2016, 04:17 AM
Porscheforever
Agreed...did a search everywhere and came up empty handed.
I figured here was the only place where I could possibly get an answer and I was right!
Originally Posted by TorqueChap
+1. One of the more esoteric posts I've seen.
Old 01-17-2016, 10:18 AM
LexVan
LexVan's Avatar
Received 5,402 Likes on 2,513 Posts
Stradivarius never had these issues.
Old 01-17-2016, 10:54 AM
BradB
BradB's Avatar
31" overall length
6" wide at neck
12" wide at the body
4.5" deep
Hope this helps. Classical instruments easily fit in classy cars!
Old 01-18-2016, 12:53 AM
philipatl
philipatl's Avatar
This board is awesome! Where else do you get questions like this...and meaningful answers and pics!
Old 01-18-2016, 04:43 AM
Porscheforever
Yes it's most definitely helped. Thank you so much!
31" overall length
6" wide at neck
4.5" deep
Old 01-18-2016, 12:00 PM
STG
STG's Avatar
Watch your back! Can't believe this guy was just casually transporting the violin. Was in my hometown.
The thief's story is even more shocking.
http://www.vanityfair.com/style/2014...rime-milwaukee
Old 01-18-2016, 12:05 PM
STG
STG's Avatar
See my link ^^^
Old 01-18-2016, 12:20 PM
Penn4S
Penn4S's Avatar
Received 1,330 Likes on 750 Posts
How about these.
bam Hightech Slim Violin Case - Orangey
List Price: $662.00
Our Price: $563.00
Savings: $99.00
Availability: Ships In 1-2 Business Days
Product Code: BAM2000XL-0002
Add to cart
Description Details Misc.
Weight: 4.2 lbs.
Full Suspension
bam Hightech Shell - ABS/Airex/PVC Triple-Ply
Exterior Dimensions: 32" x 12" x 6"
Interior Color: Black Only
Or
Bam La Defense Contoured Violin Case
bam La Defense Contoured Hightech Violin Case
List Price: $732.00
Our Price: $622.00
Savings: $110.00
Quantity in StockOut of Stock)
Product Code: BAMDEF2002XLA
Description Details
Weight: 3.5 lbs.
Exterior Dimensions: 31" x 10" x 6"
Crush Protection: The shell is one of the strongest available, surpassed only by some plywood cases (which are much heavier).
Shock Absorption: The polyurethane foam layer within the ABS shell is one of the best materials available for absorbing the shock of bumps and falls.
Thermal Protection: Polyurethane foam is also an excellent thermal insulator and Bam Hightech cases keep out the cold of a winter day quite well. The reflective nature of the brushed aluminum exterior also helps prevent overheating in the sun.
Durability: More durable than the standard Hightech shell. Scratches are not easily visible on the brushed aluminum.
Interior: Space is extremely limited. Black only. Bam offers nothing to measure or control humidity.
Ease of Travel: Best in its class. At only 3.5 lb., this is one of the lightest cases on the market for professional instruments. The contoured shape and size also make it much easier to carry than traditional oblong cases.
They aren't cheap but the sizes look right. Good luck.
Old 01-18-2016, 12:56 PM
Grunty
Grunty's Avatar
Good thing you are not a cellist!
Quick Reply: Violin case for 991 frunk
