These outer kick plates with the logo are held on by double sided tape. A blow dryer is suggested to warm up and use nylon fishing line to work through and cut through current tape for removal.
Anyone tried it? Looks too easy! I heard those ***** are easy to screw up.
I have. Turning the collar on the bottom of the shifter can be difficult, best to move the shifter to N, and use a rubber jar gripper to get a better hold on the collar. Also, pushing down on the shifter as you twist the collar makes it easier. Really is easy, hard to screw up.
OK, THPorsche, it's late and I may be missing something. I've replaced my door sills with illuminated ones and it is a bloody mess removing the factory ones. Very hard not to damage the paint. Also, replaced my red tails with clear. Pretty easy without the ducktail. But, why did you have to remove the door sills for clear tails?
