What is the current state of the 'engine stumble' issue?
#31
Mine still stumbles. It's bad. I've been posting about it over on the other forum. Stumble is usually at 2500 RPM, but with a big stumble when accelerating through 3000 RPM. On moderate acceleration I get stumbling throughout the 2-3K RPM range. Seems to be worse with humid weather, and on first drive. If I drive for a half hour, stop the car for a half hour, then drive again it seems to be better. Had a PCNA regional tech drive the car and just told me it was "normal" due to all the sensors and transitions going trying to deliver torque.
I disbelieve and still have a hard time driving the car because each drive just upsets me. Merging on to a highway should not having me lurching and stumbling to accelerate up to speed.
It's not a PDK issue. Mine is manual. Car runs very well above 3200 RPM.
I stopped posting about it here because too many people here just told me I was driving it wrong.
Edit: Here is the detailed summary I typed up for my latest dealer visit about this: https://i.imgur.com/EAYEEwF.jpg
Maybe you are driving it wrong....or expecting too much at low RPM. Who accelerates on an on-ramp at 2500 rpm?? Torque is weak down low, maybe that's what you feel. The only time I would be accelerating from 2000 - 3000 rpm would be putting around town.
#32
Originally Posted by duxsi
There was one recorded X51 owner (Money2356) who developed the stumble.
When I referenced his problem to PCNA (after he turned the car in for a GT3), their response was "He obviously wasn't driving the car properly".
Not sure where exactly you go when faced with such an idiotic comment...
The X51 has a different plenum than the non X51 cars too. Not sure an IPD Plenum would do the trick to solve this issue. Seems more to it.
Somebody needs to figure out the correct diagnosis. I'm surprised it's taken so long. Don't leave it up to PCNA. They don't care now that 991.2 is coming. Didn't care a few years ago either. I think they believe if the problem isn't widespread enough, it's a non issue. I'm sure they know what it is.
They still have GT3 issues popping up and uncertain future ones at this point, and the sister company drama as well. Bigger fires to contain.
#33
Surprise, surprise. There is driving to be done below 3000 RPM. It's not weak torque that I feel. You obviously do not have the issue.
I would love to know how you never let your RPMs drop below 3000. Please explain. Do you drop your clutch at every green light?
#34
That's a great point.
#35
You are part of the reason I stopped posting about it. This doesn't help me, or anyone else with this problem. Please stop. I'm not going to redline it in my neighborhood at 6am while leaving for work.
#36
#37
With so many good independent shops, I can't believe this thing should be hard to diagnose. Anyone ever had it looked at by a non P dealer who isn't going off the talking points memo?
#38
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
J
#39
I had read somewhere, maybe on 6speedonline, that upwards of 10% of cars may be affected. Responses so far would seem to confirm this. I tried to drive mine very carefully but did not notice anything from 2-3K. Only about 500 miles on the clock so far though.
Jim
Jim
#40
I mentioned to PCNA that my next step was to take it to an independent shop and they basically threatened me with possible void of warranty.
#41
Some of these PCNA tactics are on the verge of being "dictator like". They should be afraid of a lawsuit more than anything. Oh geez, already on the way with diesel gate. VW sales down 25% in Nov.
http://www.worldcarfans.com/11512031...25-in-november
Like I said, they have bigger fires to extinguish.
#42
this problem (since the plenum is a static part) so there is something else
going on if you ask me...
I wonder if there is any telemetry that could be extracted from the OBDII
CAN that would at least illustrate the problem when it occurs ...
the fact that this occurs around 2500-3500 rpm occurs does suggest some
issue with the intake or exhaust, as this is I believe when varioram/cam
and the exhaust switches over...
if no X51 cars had demonstrated this, I would suggest its intake related, but
since we have evidence that this is not the case, I dont think we can pinpoint
the problem to components that are not shared between the two engines
For PSE equipped cars, has anyone tried to repeat the stumble with PSE "on"? - i.e the exhaust flaps always open? - that would eliminate the
exhaust as a possible issue... so it would be intake/cam related
(another thought - is this only with 'S' cars or also base models?)
#43
I hope this issue picks up steam here. The 6Speed thread on it is amazing. Unfortunately, 6Speed has turned into a graveyard over the past year. The only hope for discussion is on RL here.
To some of the guys who have been at it for years, it may take some catching up for some of the guys on RL. Be patient. Overall, the knowledge of some of the guys here is amazing.
I hope some answers can come soon for all involved.
Money2536/Matt's old car had it and he wrote extensively about it on 6Speed. Got fed up and traded in for a GT3.
#44
I've has tried it with PSE on and off. No difference.
The fault exists with both Base and S models.
It is definitely not the vario-cam blip at 3000rpm.
This occurs before that and feels just like when we used to have a vacuum line issue in the old days.
Also note, when the DME is reset or the battery is disconnected overnight, the problem goes away. But once you drive the car again for a couple of hours the stumble returns.
So the DME is compensating or trying to correct something...
#45
Forgot to mention that when cruising at ~2600rpm on a slight incline (with or without cruise control), the tugging starts. This sensation almost feels like fuel or O2 starvation.
Another owner has had his throttle position sensor replaced and it made no difference, so a faulty TPS has been ruled out..
