tire install mess
tire install mess
I just had my Pzeros replaced with Pilot Super Sports on my C4S. Just wanted some feedback on whether I'm being unreasonable--dealer left obvious glue/dirt where old balancing weights were along
with some scratches inside the wheel. Also the crests aren't on point with the valves. They are close but not spot on. I'm confident that My dealer will take care of but am surprised at quality of service. Am I being too picky?
If the dealer did that I would never go back. Not only should they point the crest at the valve stem, they are supposed to mount the tire with the name opposite the stem, and all the crests lined up straight. Although, for some reason they seem unable to keep things that way. Wheels look great when I pick it up, but then next day in the garage they are all different directions. Maybe they are not following the newer/higher torque recommendations?
The crests have two small holes in them. They sell a specific tool made for them to pop them off, or else you can use something like a coat hanger I'm sure. That way you can align them.
The glue left over from the old wheel weights is pretty tough stuff. Dealers usually don't try and remove it. When they put new wheels on, they have to rebalance the wheel. Old weights come off, new ones go on.
Scratches are probably from them using a screwdriver to pry off the old weights. Not cool leaving scratches on there, I'll agree.
One of those things, I think through before getting done to avoid these issues. Same as telling them DO NOT wash my car as part of the service visit.
Received 5,405 Likes
I just had my Pzeros replaced with Pilot Super Sports on my C4S. Just wanted some feedback on whether I'm being unreasonable--dealer left obvious glue/dirt where old balancing weights were along with some scratches inside the wheel. Also the crests aren't on point with the valves. They are close but not spot on. I'm confident that My dealer will take care of but am surprised at quality of service. Am I being too picky?
Just rotate your caps to align the crests.
Scratches? Are you sure? That's unacceptable.
I always like the wheel lock bolt directly opposite the valve stem.
Citrus degreaser = Goo Gone. Do it urself and save urself the aggravation and stress.
And find a more Porsche-loving tire shop next time.
Yes, ur installer coulda/shouda/woulda been more careful.
Received 1,622 Likes
3M General Purpose Adhesive Remover and a brass brush(*) is what you use on the sticky weight residue. No muss. No fuss. No scratches from screw drivers, razor blades, air-chisels ...
Yeah, citrus stuff will work, but the 3M takes 1/10th as long. Just did this tonight on my loose wheels with new snow shoes.
If you are super-**** retentive, you dismount your wheels, remove the old weights, clean the sticky off, and then take them in your parts-chaser vehicle to the shop for new tires.
(*) For non-painted wheels. A tooth brush with the 3M is probably best for painted wheels.
I don't think the op is either "troll" or is "too picky"...what's wrong with this forum now?? I had my dealer order new Porsche Crests for the wheels after I noticed that pointed side of the crest isn't facing the valve stem after tires replacement and these were freely rotating. The dealer should take care of it.
they should have 1) used the universally used plastic spatula wheel weight scraper to prevent any scratches and 2) quickly and easily removed any adhesive residue with generic brake part cleaner poured on a red shop towel
even the cheapest no name tire shop operations with 19 yr old minimum wage workers do that !
( good luck , though, having any dealership tech automatically 1) index the locking wheel bolt or the wheel emblem relative to the valve stem or 2) torque with a manual wrench to final bolt tightening spec vs a quick slam of an air impact wrench , unless requested on the work order )
My specialty shop does all that as a matter of training on all cars but they are not constantly peer-compared like dealership techs who are trying to finish well ahead of the " book rate " ( especially on warranty repairs which pay by a flat " book rate " whether you are over or under time allotment ) so that they ( and their service manager who drives this main dealership profit center) can later be rewarded with performance bonuses .
As a result , they cut corners and minutes as much as they can for every / any job on their work schedule
Thanks everyone for the input (except for being called a troll). My detail guy tried everything (he claims) to try to get rid of the glue and was unsuccessful. My dealer has said whatever they need to do they will make me happy.
You're talking about glue and scratches on the inside of the wheel behind the spokes or on the outside? If inside, I think you're being too picky unless the scratches are just ridiculous. I never expect my tire changer to clean the wheel afterward. I do it the next time I wash. And regarding the glue, have you tried Goo Gone? I've yet to find anything short of epoxy that it won't loosen up.
Regarding the crests, I never even knew they lined up with the valves. Not sure why that would matter.
If it was a Porsche dealer you are not being too picky- as you paid a stiff premium for the work. Your mileage at other shops will vary, with their reputation aspirations and management.
Scratches and residual goop left on seem to be in a different class from valve stem alignment, or at least at a higher level of pissedoffedworthiness.
