Carrera vs. Carrera S brakes
The original GT3 had the 996TT 360mm 4-piston calipers, they were awesome
on the street, but a few aggressive laps on track and they were done; even
running more aggressive pads and higher temp brake fluid did not abrogate
the problem.
The car simply did not have enough rotor surface/mass to deal with the thermal
issues on track... this was cured in the 996.2 car which had the 380mm 6-piston
system installed.
based on my experiences on track in this car, and others, I would not use a
4-pot system extensively on track ... on street it should not matter, its a
simple case of cosmetics.
IMO its mostly an issue if you track your car (a lot).
the problem.
system installed.
the problem.
system installed.
Check in with Squires, he installed Turbo steels on his C4S and said they are direct bolt on. More here: http://www.6speedonline.com/forums/9...ml#post4222856 T
DanielW (09-29-2020)
Talked to someone at dealer and they asked a tech and his response was...big job, need to change spindles etc. Not was what I was hoping for.
Going from Turbo to C4S compared to S to Base might be a little more of a difference prolly. Gotta dig a little deeper into this mystery
buuhhhuuwwaaaa
Amazing car
buuhhhuuwwaaaa
buuhhhuuwwaaaa
Here's the kicker...reliable source tells me that the S rear has more pad area hence the different part numbers. Being both are at 330mm from hub to rotor edge might be the S rotor would have a bit more area. SO, I'm thinking for a Base rear to be upgraded to S rear just the rotors, calipers and pads needed to be doable So if that's the case, $1600 from one dealer for S to Base swap might be less at different dealer tho. For the fronts @ $1995 + $1600 = $3595
Like the OEM would be 1/2 the price of a real aftermarket big brake kit...you decide
But...is there anyone out there that has done a 991 REAR Base to S as of yet? imho the only real way to see is if someone has done it OR for someone who has access to parts to have a side by side comparison.
Sorry so long, did not want to paint my calipers...lol
Is the heat capacity problem in the calipers, or the rotors?
Girodisc sells a kit that puts 350mm two-piece rotors on all four corners for $2400 (with spacers to move the 3.4 calipers). Thoughts?
wdr911 (09-30-2020)
That's in line with the Racing Brakes kit ($2800) which gives you their pads and 380 discs all around, and relo brackets for OEM calipers. But I don't think they allow a Base-to-GT3 conversion, only S-to-GT3.
http://www.suncoastparts.com/product/PK981SBRA.html
Looks like only disc for S and 4S only, no luck on Base 3.4L:
http://www.girodisc.com/Rotors_c_1119.html
On the 991.2's it's a direct swap. I put GTS brakes on my base. It was time for rotors and pads on all 4 corners and I found a used set off a .2 GTS with 2,000 miles. The rears are the same BTW.
Onad (11-18-2020)
I have a chance to buy calipers from the S (fronts) for my base car. I don’t really want to buy the discs because the shipping is crazy expensive. Is the calipers alone a good upgrade and will it work with my current base front discs?
Do you find a noticeable increase in braking power on yours now after you’ve had them a while compared to stock?
