US Spec 991s in Europe Questions and Experiences
#31
Thanks - I may be dealing with this next year, so will reach out then. I brought over a Honda Element to Luxembourg in 2014 and it wasn't a big deal - just had to change the lights and that was all. Just curious if anyone has done this with a Porsche so that there aren't any expensive surprises...
#32
It's 100% possible, but may be challenging depending on the model and EVERY car will most likely require special attention. Do not just accept broad statements of certainty from online forums, you need to talk to customs first and then seek the correct inspection depending on the country.
I can mostly speak to Germany, but you would need to pay the 19% VAT, 10% customs fees, plus shipping fees, and then get a TüV inspection done. They'll tell you what you need to change, if anything at all.
Good luck.
#33
I've been looking into starting a small import/export business from US to Europe and what I've found is you need to get the cars inspected for the local registration system and they'll tell you what modifications you need to make in order to get it federalized.
Good luck.
Good luck.
#34
There's also no tax requirement I believe if you plan on only being here for less than a year.
These rules do not relate to US military...
#35
Is this for Germany specific? There are two sets of rules for EU and non-EU countries. The tax burden is almost non-existent if you're transferring between EU countries, but changes under specific rules.
duxsi (04-29-2021)
#36
There are so many factors and facets to importing and exporting and only mentioned to consider that when taking advice from online strangers.
#37
I know that if you are moving to Luxembourg, and if you have owned the car for over one year, you can import one car (only) tax free. The car has to enter at the time of your household goods though - you can't move your stuff and the bring the car over later on. I believe this is consistent across many of the EU countries (but not positive).
It's definitely a risk though if you don't know until after you arrive how much you will have to change in order to be compliant. When the time comes ,I will contact Porsche to see if i can get more info - I suspect the changes will be limited to lights.
#38
Also, and this may or may not be specific to Sweden, but there are two parts to the import rules. The first relates to the tax/customs situation (as outlined above). The second relates to the technical requirements and will also vary depending on ownership term prior to import. If I remember correctly, if you have owned the car for over 18 months in the US prior to import as household goods, there are virtually no demands on modifications (I think you will even get away with red US rear indicator signals for example). As stated elsewhere though, spend some time doing your own research!
The following 3 users liked this post by SwedeInNY:
#39
In most cases, Italian customs allows a one time duty free import of goods as part of your international move to Italy, as long as you meet the following requirements:
- Items have been owned for at least a year
- You have lived in the country of origin more than 12 months
- The goods are at least 6 months old and have been used by you
The following 4 users liked this post by theracer21:
#40
Does anyone know if it's limited to one car per household?
When I last moved back to the UK it was extremely easy to import (1 year of ownership before entry, Cert of conformity, and you couldn't sell it for 1 year).
Was anyone required to change the speedometer face plate? This isn't necessary for the UK (mph to mph), but this time I'm heading from the US to the mainland w/ kph..
Thanks in advance.
Thanks in advance.
#41
Thanks in advance.
Thanks in advance.
#42
I'm importing my 2013 991 C2S to Italy. I will replace the rear lights with the amber ones, but has anyone had issues with the seat belts? Also any advice on how to fit the European rear license plate? I will be happy to let everyone know how my experience goes...
#43
Reviving an old thread from the dead... I noticed 991 rear bumpers are different between US and EU spec. I have a US Spec 991 coming next week and need to do my (US-System registration) inspection and I have no front bumper license plate mount. I was between getting a tow hook mount or having the local Porsche dealer drill holes into the front bumper for the euro license plate, but the rear would be a US-style license plate.
Also, the temp tags they gave me are complete trash and there's no place for me to mount them on the car. Really concerned I'll get stopped for having the front plate in the windshield until I get the front mount.
What do you guys think? Drilled holes or nah? I know most will say not to do it, but I've been considering selling my 991 in the Euro market after I'm done here and maybe I should just go ahead and knock that out. I don't know how I feel about having two different size plates, however.
#44
If you are moving to a country that has a US government presence, they will likely have the US sized plates for the rear and you won't have to modify bumpers. The front will be a Euro plate mount. I just commented on that.
#45
Thanks, I asked and apparently, in Italy they only have two formats for the rear. One long one which is 52 cm × 11 cm; and one square one 29.7 cm × 21.4 cm. The long one is too wide to fit and the square one is very large and unsightly ;(
Did you have any issues with the seat belts?
