Reserve your 991 DSC module
#211
Have anybody installed DSC in a 991.2 Base Carrera ?
In my 991.2 I don't use normal suspension mode since the car feels like it's floating and I just don't feel safe when I'm driving at higher speeds. Because of that, my suspension is always at sport mode.
I would like to have a softer setting but still have that "totally in control feeling" that I'm lacking today with the normal suspension mode.
#212
The short answer is "yes"; understand that PASM-S is simply a more aggressive spring and ARB/sway bar package for PASM, AFIAK a PASM-S car has the
same dampers/shocks and PASM controller as a PASM equipped car.
PASM dynamically adjusts the dampers valving in order to change its compression and rebound, DSC takes the adjustment of that to a higher,
and customizable, level... allowing it to do things such as, stiffen the
compression of the front shocks when the car brakes, thus reducing nose
dive, or stiffening the 'outer' shocks when a car is cornering, thus reducing
roll to the outside of the corner (as PDCC does by hydraulic adjustment
of the the ARB/sway bar linkage)...
in short, PASM, and DSC makes the response of your suspension adjust
to the road conditions and dynamics of the car.
If you drive your car like a soccer mom in a minivan then you probably
wont benefit from DSC, but if you drive your car at all spirited, then you
will notice an improvement in its responses...
Also note, especially for PASM-S, cars, with a higher spring rate than PASM,
if you find your "normal" street experience unsatisfactory due to the
stiffness of the suspension, DSC can reduce the aggressiveness of the
effective spring rate of the car to make your daily ride smoother so your
(mr my) latte does not spill!
Anyone planning to install this in the 991.2 GTS w/ SPASM?
I did not order PDCC and wondering if this is potential solution to make up for not having PDCC.
#213
Has anyone tried to update their firmware ? Thinking if i should update it if it would make a lot of difference, always have this fear of bricking equipment when updating firware
#214
I finally got a DSC V2 Controller and installed it. They had been out of stock for some time, but are back in stock and mine arrived very soon after ordering it. Installation as noted in the videos and others' comments was pretty easy. The most difficult part was removing the larger of the two harness clips. It was really tight on my car. But knowing that it *would* come out eventually, based on others' reports, helped immensely. Once out, it literally was a snap to install the DSC, as the connectors easily slide in and locked. The wiring harness is pretty tight and doesn't "give" much. You will need to be rather forceful to pull the OEM unit out enough to be able to gain sufficient grip and leverage to slide the clips off, but don't pull so hard that you break any of the wires or their connections.
If you are at all in tune with how your car rides and handles, you will immediately notice the difference, even when driving moderately. The DSC map gives the shocks greater range, at least on the soft end, where it produces a noticeably better ride than stock, and you will find that on bumpy roads, the car is more compliant and the tires stay better in contact with the road surface. I don't know if the shocks are stiffer on the stiff end, but the dynamic adjustment really works to make the car handle better. There is noticeably less dive and squat on acceleration, and cornering is flatter, almost like having PDCC (which my car, at 991.1tt, doesn't have).
For a variety of reasons, I'm not keen on an engine software tune (and we only have 91 octane fuel here anyway), but the increase in chassis capability is something every car with PASM could benefit from. My only regret is that I didn't get this unit sooner.
#215
#216
I've been able to play with the shock calibration to give a firmer (yet more compliant) ride than OEM with the dampers in normal mode with sport mode being fairly stiff and lively.
#219
Based on the comments by many, and my own experience with how the DSC module affected my car, though, I think that the effect must be pretty similar to PDCC. In fact, it’s better in some ways, because it helps the car reduce dive and squat, which remain unaffected with PDCC. The DSC is way more cost effective than trying to retrofit PDCC, or sell my car to buy another with that option. If you at all feel regret for not having PDCC, I highly recommend you get the DSC Sport module.
#221
https://rennlist.com/forums/991/9679...2-support.html
Also I bought it second hand so returning it will be a problem..
#224
#225
If it helps anyone... I was having issues with dsc and traction control conflicting on. My 2015c2s. I set minimum shock stiffness to 20% and 80% for normal and sport chassis modes respectively. Immediate improvement. Product is awesome.
