Wheel Help
Old Sep 13, 2015 | 01:20 PM
G8tor's Avatar
G8tor
Default Wheel Help
I have a C2S with turbo wheels I'm looking to replace.
According to the owners manual the rears have an offset between 68-70 (both are listed in the wheel data and it doesn't differentiate between the different wheel options).
I see a set of wheels I would like that came from a 911 Turbo that have an offset of 56. Would these work with a spacer?
Thanks in advance.
Old Sep 13, 2015 | 04:23 PM
Slantnose!'s Avatar
Slantnose!
No, offset is wrong way...spacer would make it stick-out worse.
Old Sep 13, 2015 | 05:27 PM
G8tor's Avatar
G8tor
Thanks for the feedback
Old Sep 13, 2015 | 05:58 PM
p987yow's Avatar
p987yow
As above, the change in offset is like adding a 12 or 14 mm spacer. Which I think would look good. I have 17mm extended on my 5-lug GTS, though you wouldn't want to go more aggressive than this.
Old Sep 13, 2015 | 06:18 PM
Larry Cable's Avatar
Larry Cable
Team Owner
this explains the offset: http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Sep 13, 2015 | 07:03 PM
G8tor's Avatar
G8tor
I just checked using a straightedge and level. 1/2 inch would put the outside edge of my tire just flush with the top fender flair. I'm concerned about getting spray off the tires onto the body, we get a lot of rain here, raining now.
Old Sep 15, 2015 | 12:18 PM
ltdodge's Avatar
ltdodge
i have some carrera classic I am selling for a c2s. Not sure if you are interested in these? Im in Orlando.
