Hill Hold feature
BJK is quite correct above. His sequence of keeping it in neutral but depressing the clutch and the brake avoids the hill hold but takes a different level of coordination. Taking my foot off the brake and simultaneously slipping it into gear and then hitting the throttle and popping the clutch should work but may be too much to expect of this 71 year old. I will try it in the morning.
I was taught not to keep the clutch in while on a hill; apparently something to do with increased wear on the mechanism...
select neutral
coast to a stop
hold on foot break
when ready to move off, depess clutch, select gear, bring clutch up to just before the biting point
release brake and move foot to accelerator
release clutch at the same time as depressing accelerator
voila - a hill start
select neutral
coast to a stop
hold on foot break
Larry-
That is the way I have driven a MT vehicle since I was sixteen. However, as you recognize from your new GTS, as soon as you put it in gear and remove your foot from the brake and move it toward the accelerator, it is in hill hold before your foot hits the accelerator.
Received 2,869 Likes
Needmoregarage-
You got it! "...... sometimes it's holds a bit too much for my liking.....".
It engages the emergency brake on a hill. It takes more RPM when the clutch is popped to override and disengage the emergency brake. Gives you a little snap in the neck and the PSE roars. It is sometimes embarrassing. After 5 MT Porsches dating back to 1974, I know how to operate a clutch and accelerator on a hill without the car sliding back. Call me old school.
Well this explains it. Perfect! Now I don't have to reread the manual.
I have auto start turned off plus I'm always in sport plus mode.
I never have the clutch to the floor held while also holding the break.
If I'm stopped I am off the clutch and in neutral. When I'm ready to go I press the clutch put in first and off I go.
Sent from my iPhone using Rennlist
Hill hold should work just the same with auto start/stop turned off as it does with it on.
Even worse was driving three different Sciroccos on those same steep SF hills 35 + yrs ago ....front wheel drive car , add in some foggy streets with polished cable car tracks undeneath you ....in stop and go traffic moving inches at a time and there was alternating slipping clutch smell or unloaded madly spinning front tires desperately clawing for traction
Curiously, one of the worst hills in Stuttgart is on the exit from the Porsche Museum Parking Garage. At the top of the steep incline you have to stop and put your ticket in the machine to raise the gate and exit. That's where I first encountered Hill Hold. Stalled it out twice. Realized that the secret to Hill Hold is to release the clutch at a slower than normal pace. Releasing it like normal doesn't allow it to release. Now I enjoy the feature.
Pavegeno928 has it quite correct:
I went out and did just what he recommended. Releasing the clutch gently on an incline releases the Hill Hold inconspiculously.
Thank you all!
Thank you all!
djo715 (05-02-2021)
