Porsche Entry and Drive - Am I Missing a Part?
Yes, I think you are missing a part. I think that is the piece that you need to remove if, for some reason, you need to remove the dummy key. There is a tool that you use, once that trim piece is removed, to remove the dummy key.
https://rennlist.com/forums/991/8179...-easy-way.html
See here ^^^
Don't mean to hijack, but how DO you remove the dummy key? Although I don't know why I would ever have to.
Leave your FOB key in the house. Got to garage and try to turn car on. MFD will give you an error message. Turn dummy key to the left and you will be able to remove it.
Take the removal tool on the back of the driver fuse panel, and go down to your local P Dealer. Get in any model and steal one.![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Or just contact the parts department and have them order you one!
Smartasses
Those are Cole Haan driving mocs!
Only if you get two different error messages back to back in the MFD , then you hear a click when you shut off ..remove dummy key immediately , or it will be locked in again if you dawdle for even a couple seconds
Dummy key removes without a tool.
See here ^^^
See here ^^^
