991.2 - rear steering, over boost for 120 secs and more
New story in Autobild magazine reporting some interesting new features on the 991.2 that I don't think have been reported before. They are also reporting that it sounds good too.
- increase of 20bhp from the current models, (though my SA is still adamant that the S is 430hp and increase of 30); 500Nm torque available from 1700 rpm with a redline of 7500 rpm;
- an Overboost button, which lasts for 120 seconds cuts the 0-100km/h by 0,2s to 4,3s for the Carrera and 4,0s for the Carrera S;
- PASM can lower the car up to 20mm in Sport Plus;
- new steering wheel button has an Individual mode to save the driver preferences; (at last!)
- Chrono Plus Package gets all-wheel steering from the Turbo; (this will be interesting!)
- front lift function, up to 50mm (Ilike that)
- PCM has multi-touch (again my SA is adamant that it will support Appleplay)
A lot of good features if they work out. I am guessing Porsche is being conservative in their numbers, both with HP and times. The S already breaks the 4.0 sec to 60 with launch, guess the new one will be in the 3.6 - 3.8 range.
Are you saying the 991.2 is going to have adjustable ride height?
Probably just the pneumatic front lift system like on the GT3. There is no way Porsche will fit an air suspension system like the ones on the Cayenne and Macan, since it is nearly impossible to achieve the spring rate and damping quality that is needed on the 911.
Nor do I see the possibility of installing a set of height adjustable coilover like on the GT3, considering the model hierarchy.
Imagine if they had done like I wanted and made RAS an option on today's GTS. What a car that would have been!
Here is a link to the story http://www.autobild.de/artikel/porsc...t-5869319.html
They are reporting a weight of 1475kg for the Carrera S.
One other item I missed is there will apparently be a factory tuning kit boosting Carrera S to 450 hp. Now that will be tasty.
Originally Posted by cloud9blue
Some key points that wasn't mentioned before
60lb (30kg) increase in weight. Active aero for the intercooler ducting. Retuned steering.
The front aero's will close after 9mph then open again at a higher speed. I think something like 80mph+. The details were posted somewhere.
All the other points and the info in here were mentioned in one of the seven 991.2 threads. I believe the same article was quoted.
PASM -10mm
SPASM - additional 10mm
Fixed. Won't be air suspension that can raise/lower
60 lbs is a lot. It's like a big bag of gravel
60lbs would be significant for a stripped down GT3, less so with a street orientated Carrera. I highly doubt anyone here can tell the difference in handling unless you have the skills to drive these things at 10/10 pace on a track.
Plus, we can always go on a diet to get some extra weight saving.
I am told that the 991.2 C2S has an exhaust note very reminiscent of an American hot rod.
Sort of a deep throaty growl, very much unlike the current iteration of the 991 TT/TTS exhaust note, which in stock form sounds like a balloon with a hole in it slowly leaking out air.
