Help - Fault engine extract. vent.
Warranty ? On a 2012 ? Are the fans somehow warrantied longer like exhaust ? (not debating your statement, genuinely asking). I am doing a lot of stuff myself since warranty expired, so I want to file that one for future reference.
My 991 is in the shop of this same reason. One of motors died I think this is the engine vent fan. https://www.pelicanparts.com/More_In...VJmRoCIU7w_wcB
Help
This is my first post here on Rennlist. I have a 2012 991.1 and got the same message yesterday. I’ve made an appointment to take it in to the dealer but it’s not until a week from today. Just wondering if it is okay to drive around with this for a bit until i get it fixed.
thank you,
Hello everyone,
thank you,
thank you,
Welcome! I'd guess you'll likely be ok if it's cool out but I wouldn't drive it on a hot day (or track type driving) with a fan failed, especially if you get stuck in traffic. FWIW it's like a 15 minute swap out so worth considering DIY if your car isn't under warranty.
The way P-techs are troubleshooting this is by checking the code via PIWIS (P1670, fan unit 1, left side). They then swap sides with your existing blower units (they just snap in) and verify the code remains the same or changes to P1672 (fan unit 2) if it changes as mine did, its a specific fan unit drawing more current than Porsche thinks it should and requires replacement. Interestingly both my fans spin up, one just trips a code because of excessive current draw...
I double checked as per your suggestions and it is secure. It make no sense, as the display states, there is a fault, yet it works. Anyone has any idea?
