Chassis Stiffness Comparison
Old 05-31-2015, 11:12 PM
SDaddy
SDaddy's Avatar
Default Chassis Stiffness Comparison
Thinking my GTS had high torsional rigidity, I did a quick search and found the following highlight from YouWheel: All values in Nm/deg.
Does it seem right that a Hyundai sedan is more rigid than a 991 GTS
Ferrari 458 33,120
Fisker Karma 35,000 (bending: 23,000)
Hyundai Genesis Sedan (2015 -) 39,400
Jaguar F-Type Coupe 33,000
Koenigsegg Agera 58,000
Koenigsegg Agera R 65,000
Lamborghini Aventador 35,000
Lamborghini Gallardo Super Trofeo Stradale 35,000
Lexus LFA 39,130
Porsche 911 Carrera Type 997 33,000
Porsche 911 Coupe 991 (2012) 30,359
VW Phaeton 37,000
Old 06-01-2015, 12:25 AM
autobahnA8
autobahnA8's Avatar
Wow - koenigsegg is double the 911!
Old 06-01-2015, 01:19 AM
thomnellie
thomnellie's Avatar
Ferrari 458 33,120
Lexus LFA 39,130
VW Phaeton 37,000
And it weighs only about a 100 pounds more than a Targa 4S
Old 06-01-2015, 08:35 AM
CliffJumper RS
CliffJumper RS's Avatar
It's also interesting that the 991 is a slight step down from the 997...
Old 06-01-2015, 03:22 PM
Axxlrod
Axxlrod's Avatar
Hyundai is lying.
Old 06-01-2015, 04:22 PM
Grunty
Grunty's Avatar
Isn't the koenigsegg all CF which would explain bonkers rigidity.
Old 06-01-2015, 04:32 PM
Noah Fect
Noah Fect's Avatar
Received 1,299 Likes on 886 Posts
My guess is that a rear-engine, RWD platform simply doesn't need that much additional stiffness. No part of the chassis is exposed to significant driveline torque.
The C4/Turbo cars are an obvious problem with that reasoning, of course.
Old 06-01-2015, 05:10 PM
Tcc1999
Tcc1999's Avatar
The problem with data like these is that they get presented independent of all other factors with the implication that a higher number is something that somehow makes the car better. Look at the number for the Lotus Elise, 10,000. Would anyone call this car a noodle. It is a mid-engine car and its torsional rigidity is probably more than acceptable given the way it puts down power. And therein lies the key, as stated above. If a car is the sum of its parts, torsional rigidity is simply one aspect. Suspension, engine, engine location, construction materials and location, etc. are all variables. I do not mean to say that the numbers are made up or exaggeated, just that the cars are engineered to meet certain performance expectations - a little more "X" and a little less "Y", and so on, makes the car what The manufacturer intends it to be (ideally).
Old 06-01-2015, 05:29 PM
ipse dixit
ipse dixit's Avatar
Received 11,532 Likes on 5,058 Posts
Bingo.
Like saying a woman is beautiful simply because she wears a DDD bra.
Old 06-01-2015, 06:00 PM
Larry Cable
Larry Cable's Avatar
Received 3,596 Likes on 2,340 Posts
Bingo.
lets talk about "chassis stiffness" now...
Old 06-01-2015, 06:06 PM
Bishop200
Bishop200's Avatar
Oh, to give Christina a ride in my 991...
Old 06-01-2015, 06:19 PM
ipse dixit
ipse dixit's Avatar
Mine is certainly stiffer.
Old 06-01-2015, 06:28 PM
Larry Cable
trust me to debase this thread
Old 06-01-2015, 07:47 PM
Bishop200
Bishop200's Avatar
How can an awesome photo of Christina qualify as debasing a thread? Supercharging it maybe
Old 06-02-2015, 09:06 AM
jumper5836
jumper5836's Avatar
I believe that is wrong or the Cab. Porsche used 20% torsionally stiffer as a design target over the 997, has claimed "up to 25% stiffer"
some other info I found based on 911 model differences
'88 911 7k nm/deg (measurement by burgermeister)
964 11.5k nm/deg (993 was 20% stiffer)
993 13.9k nm/deg (996 was 45% stiffer)
996 20.1k nm/deg (Excellence was Expected p.1381)
996.2 25.1k nm/deg (996.2 was 25% stiffer)
997 33k nm/deg
991 40k nm/deg (porsche used 20% torsionally stiffer as a design target, has claimed "up to 25% stiffer")
also
Porsche 911 Turbo 996: 27k Nm/deg
Porsche 959 12.9k Nm/deg
Porsche Carrera GT - 26k Nm/deg
987 Boxster 16.5k NM/deg
981 Boxster 23k NM/deg (40% more)
987 Cayman 30k NM/deg
981 Cayman 40k NM/deg
Quick Reply: Chassis Stiffness Comparison
