Feedback on a GTS order?
Received 5,407 Likes
Car with PASM is 10mm below sea level.
Car with Sport PASM is 20mm below sea level (another 10mm below PASM).
Ditto. I went in thinking I might want it, but to my butt, it's an artificial feel, devoid of some of the feedback I want to feel before all hell breaks loose. Plus, it's crazy expensive, and I'm not sure it does much of anything but make the driver feel like he's going faster through corners. But I could be wrong about that.
like about that pile of sh*t ... wait I digress ... but IMO there isn't a 911 built
that needs this function unless what you really want to buy is a Lincoln Town
Car with better handling in corners ... there I've said it!
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Also a number of owners (daft enough to tick this box in the 1st place) that also track their cars have reported PDCC faults while on track ...
its not for me, I see the value of PASM, but I draw the line there... and if I
could have specced Sport-PASM on my hairdressers GTS cabriolet I would
have ... but I'd rather **** the money elsewhere than on PDCC ... YMMV
that's fixed, what's different is the (static) ride height and spring rates etc
Uncheck the 'SportDesign' wheel option in he leather section and you'll get the alcantara wheel/shifter. It comes standard on the GTS and by adding the option you're actually replacing alcantara with leather. If you haven't already in the configurator use the 3D/360 mode to confirm your selections, works great.
What are the CL wheels? I see Turbo S and Carrera S wheels as an option. (I wish there were more choices, as I don't love either of these; not a big deal 'though.)
I test drove a GTS last night with the multi-function wheel and although the car had PDK, I assume the wheel was pretty similar. I didn't like it compared to the SportDesign wheel on my current 911. It seemed bigger (i.e., diameter) and thinner. Seems like I'll probably just need to get the SportDesign leather wheel if I want it's shape. Hmm...
If you get the backup camera, do you still get the audible warning? My wife’s car has an audible warning and no camera and it works great. I’ve driven other cars that had a backup camera but no audible warning and I hated it.
On the flip side of that -- you won't be carrying a spare anyway (911 doesn't come with one since 2005), and if you get a flat in the boonies, what are the chances Hiram down at the Shell station has a 305/30-20 lying around to replace it with?
Or you can spend about $600 and buy the tools for removing, and just carry them with you when travelling out of civilization. But you still won't have a tire.
You done good IMO, great color combo.
Others have good suggestions, here are mine....
PDCC, not a fan, didn't order.
Sport PASM, tested thoroughly, didn't order. Like the stock PASM calibration & height just fine. I don't want any risk of gouging the front end.
Went with the CLs,....yes I will be buying the tools to remove them 'cause I like this type of stuff! These wheels are also 1/2" wider all the way around, fill out the wheel wells a bit more. IMO part of what makes a GTS.
Like the uncluttered look, so no Sport Design or Duck Tail, did go with the best color though, Carmine Red!
Did order some extra carbon in the cabin.
Burmester is to die for, one of the first boxes ticked. Have it now.
Good luck!
Good luck!
+1 to the map pockets and smoking additions, its nice to have the extra power outlet.
I've been really happy with PASM sport. It is low and gives the car a great stance. As long as you crab over speed bumps / up driveways, scraping is not an issue. I was also pleasantly surprised with the ride, I expected it to be harsher than it actually ended up being.
As for the ride height, I have a lowered Turbo now (aftermarket springs) and I've learned all the places I have to ease over sideways; a GTS on SPASM rides higher than the front lip of my Turbo, so that part doesn't bother me at all.
