GTS Redline
#47
I'm aware of those as well. The intake flaps are there to not limit low end torque while the cam is there to produce higher hp with revs. It's bin the recipe for ever in motor sport.
#48
Depends on the increase of the lobe whether lift or duration. Fine tuning the balance can produce more torque lower or higher hp in the upper range. Cam shaft changes don't necessarily equate to higher rpm capability. Valves, lifters, gaskets, head bolts, piston profile, combustion chamber profile, injector size, port flow, etc all play a part. Usually why cam profile changes are relatively small.
#49
That's what I suspected, difference between red line and fuel cut off limiter. Would like to know how the dme logs over revs and what the threshold values are for stage 1 and 2 specifically.
#50
#53
#54
#56
The GTS is a great packaged car with a nice price break. I love it!
I don't think there's some secret tune/boost that Porsche is keeping secret about. They'd maximize anything for additional sales.
It's an S with a Powerkit. All this reading between the lines with creative journalist writing is a wild goose chase.
Add the Widebody, Centerlocks, Alcantara, and a few grills you're there.
"You put lipstick on a pig, it's still a pig"
#57
As even Ford doesn't do this. When the Boss302 came out it had a 7500rpm redline, and it showed so on the tach. Not the 6800rpm redline the regular 5.0 Coyote equipped GT showed on its tach.
Also, redline on the tach for the GTS and non GTS shows 7600rpm but that could be what redline is not fuel cutoff.
Dave
#58
When one gets down to brass tacks redline is 7600 rpms, the redline mark on my tach is 7600 rpms. In a earlier PDK thread I mentioned that the computer allows the revs. to pass the actual redline marker on the tach. The limiter kicks in at 7800 rpms. and that would trigger a tattle tale report on the computer report. Do I have this right? Why is this so murky?
#59
It gets a little murky when the maximum PERMITTED engine speed is actually above red line and in this case by 200 rpm. In my experience the limiter is usually set much closer to the indicated red line. By having the above language in the manual I think they'd have a hard time arguing damage between 7600 and 7800 if you had an issue.
And besides what would we talk about on forums?
#60
